I have fixed the problem with new high temperature radial capacitors on the LED board. Ebay has an overhaul service posted which will take your old unit in and rebuild it for $160.00. This is cheaper than any kit, and you are guaranteed that it will work when it returns.I have fixed the problem with new high temperature radial capacitors on the LED board. Ebay has an overhaul service posted which will take your old unit in and rebuild it for $160.00. This is cheaper than any kit, and you are guaranteed that it will work when it returns.
Good Morning, We have control boards for this model in our inventory for sale, and we rebuild them. We can repair the dimming display, or replace the glass display if needed. All control boards we sell and repair are fully tested for 100% functionality & come with a two year warranty. Reach out to us for more information.
512-355-1108 fixyourboard.com
Good Morning,
512-355-1108
fixyourboard.com
You can't post conmments that contain an email address.
I have just repaired two SC301 ovens myself, but it is alot of work. You can get the oven's LED lights reconditioned at a company called CGI industries. Look them up on the web and click on the link for thermador. Removing the led panel and oven relay board is an involved job, but easier if you do it the correct way. First, turn off the power to the oven. Then pull the oven out of the wall socket about 1 quarter of the way. Remove the top cover of the oven with a phillips screw driver. This reveals the oven relay board. Take a digital picture of the board to remember the wire positions, or alternatively write them down. You also need to remove the touch panel (two screws underneath) and gain access to the LED. Remove the LED panel and wires. ship both to CGI (boards only) and you will have them back in less than a week. Costs about $170 before shipping. Reinstall and turn power on. All is good.
Dim display is TOTALLY independent of F7 error.
The display will dim as the display board capacitors wear out - due to the heat. Replace the capacitors on the display board (see my other posts) and your be able to see the F7 error code as bright as can be!
there is a dispay kit you can order from bosch to fix this problem. it will come with a new display board and power control which is located behind control panel as well
Have 2 Thermador ovens, SMW272 and SC302. Both have display failure. Just repaired one with replacement display. It did not require a new control unit or harness. Have not opened up second unit yet as display is still dimly/slightly visible.
Called Thermador and received no offer of replacement parts or service. Numerous other web reports of similar failures. My neighbor has 2 dead ovens also unfixed because of outrageous repair estimates ($600 each). Do not recommend this brand.
Full kit including display, control, and harness ordered on Ebay for $170.
You are going to need a display kit to fix this. It comes with a new display and relay board. The kit is about $200 and is somewhat difficult to install. This repair altogether usually runs about $400 to fix if you dont have someone handy that can do it for you. It involves removing and replacing at least 20 wires from the relay boards, as well as either pulling the oven from the wall or working in a tight space to change the board. You may be able to find just the display board somewhere, and that is very easy to install, but I've only ever gotten the part as a kit. Hate to be the bearer of bad news. Good Luck!
Good Morning,
512-355-1108
fixyourboard.com
