Question about Haier Refrigerators
Haier HSW02C runs ALL the time
My Haier mini fridge started freezing things a couple of days ago. I adjusted it from 5 to 4, and it froze worse. Oops, must have read the scale backwards. Went to 6, and froze even worse. Turned it to OFF, and it kept running. Uh-oh. Unplugged it overnight, plugged it back in, with the dial on "off" (I can feel the dial "click" between "Off" and "1"), and it started right up. Seems like it runs 100% of the time when there's power. Bad thermostat? Looks like a $15 part. Hard to replace? I don't know. Is it worth putting $15 into an 8-year-old fridge that I could replace with a new one for about $70?
    Habit-Forming:
  • 107 Answers
Yes your thermostat is shorted. It's just not shutting the unit off ever. A thermostat is something you can touch as a user, so no it's not that hard to get to for replacement. Also have the unit unplugged while learning how to repair your appliance.
Posted on Apr 27, 2013
6ya staff
SOURCE:
IFIXALL
Archie Ferrarini
  • 869 Answers
SOURCE: We have a Whirlpool gb22dk
1st.Check the freezer door gasket for any place it maybe torn or not making a 100% seal when you close the door.That would make temperature drop. 2nd.take off bottom kick plate so you can look under the refrigerator.Using a flashlight make sure there is not alot of lint / dust stuck on the coils .If there is remove it carefully and you will see temperature lower. PLEAS RATE THIS!
Posted on Jun 09, 2008
Anonymous
  • 1142 Answers
SOURCE: Fridge and freezer on GE GSS25SGMDBS not working
see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Posted on Aug 07, 2008
Anonymous
  • 89 Answers
SOURCE: My True beer fridge is freezing inside.
call repairman sounds like low on freon or thermostat problem either way better to have pro do it hope this helps
Posted on Sep 05, 2008
Carmen Mikulic
  • 415 Answers
SOURCE: clicking near compressor but doesnt
since your mini fridge is under warranty, have a technician come and take a look at it. i would say it's the damper.
Posted on Sep 13, 2008
Anonymous
  • 340 Answers
SOURCE: my fridge won't cool down or freeze
Your condenser is likely dirty clean it. the compressor could be tripped out on over load (to hot) unplug the fridge a couple hours should do it . plug it back in make sure the thermostat is on and set correctly if that does not work you will need service. Tom
Posted on Jun 17, 2009
What can I do to fridge to stop it from freezing everything. its a haier mini fridge
There should be a thermostat, perhaps it needs adjusting or perhaps it is faulty and should be replaced.
Dec 28, 2017 | Haier Refrigerators
I have a haier mini fridge model #HSW02C when i plug it in it humms for a few seconds then it clicks then i hear nothing could this be the relay? any sugestions?
I would say that the motor is humming because it is not turning and the click is when the overload control switches the power off. It may be a start run capacitor blown out but it may be a seized compressor motor. have a fridge mechanic check it out.
Oct 13, 2013 | Haier HSW02C
Haier CFL-CFE f/f is very noisy
Intermittent noise is usually a sign that it is not flat/ on an unstable floor. The truth of the matter is that all appliances today are built cheaper as time goes on and that makes funny things happen including noise.
The fact that it is not happening all the time tells me that it is not a mechanical failure. IE: if a motor goes bad,it stays bad and does not have mood swings 3 times a day!
Easy fix.. When it starts making noise,just put your hand on the side of it and gently push. If it gets softer/goes away then you need to shim a corner or adjust the feet (most delivery guys drop it and leave. They do not adjust feet/ doors/ or anything. They just deliver) You can try different parts until you get it right but the hard part is being there when it happens
Feb 01, 2018 | Haier Refrigerators
Haier refrigerator hsw02c does not run
These are pretty simple units. If you look on the back you will see a schematic. More or less there is an overload protector in series with the thermostat in series with the compressor. If the overload protector is not open and there is still no 120VAC at the compressor with the thermostat turned all the way up then the answer is a bad thermostat. If there is 120VAC at the compressor and it is not running then the compressor is bad. That's about it.
Jun 09, 2012 | Haier HSW02C
My Haier mini fridge (model # HSW02C) is freezing everything in it's contents no matter what number setting (1-7) it's on. Is 1 supposed to be the coldest setting, or is 7? What should I do?
Hello
Number 1 may be the warmest.Set it to 2 or 3 and give it some time,a couple of hours to level out.
If this does not work try a higher number.
If still no luck then the thermostat or sensing bulb is bad and should be replaced.
Mar 24, 2011 | Haier Refrigerators
Haier mini fridge model hswo2c not working
on its side? considering the chemicals inside the freezing elements, it needs to sit upright for 24 hours before you plug it in, or you may break it. so if thats what you mean, why is it sideways?
Jul 24, 2010 | Haier HSW02C
My fridge won't cool down or freeze
Jun 17, 2009 | LG LFD25860
Car won't run after rain or after it sits for a couple days
you need a tune up new plugs wires and cap an rotor
Nov 07, 2008 | 1990 Geo Prizm
Refrigerators Logo
123 people viewed this question
Top Haier Refrigerators Experts
Vernon Taylor
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
