PDF
Nov. 12, 2015 - Installation Manual. Additional Digital Cordless Handset. Model No. KX-TGEA40. Thank you for purchasing a Panasonic product.
16 pages
However, using the correct search query, it is mentioned here, top of the page. I can't paste, because symbols don't work.
I have similar phone. Press Menu then enter #217 to edit blocked numbers. Use up or down arrow to scroll through numbers. You can erase or edit blocked numbers.
For more info, see manual at: http://www.manualslib.com/manual/754430/Panasonic-Kx-Tge210.html?page=1
Access your blocked
call list. Go to the main menu and scroll down; it should be one of the
options listed there. Push the "Enter" key to access the blocked list
once it's highlighted.2 Scroll down the blocked call list until you find the number that you want to unblock.3 Highlight the number and delete it from the phone's list.
Are you saying that you've blocked someone from calling your cell phone? If so, thats typically handled by your cellular provider and you would have to contact them to unblock a number from calling you.
Only the sim is blocked, not the phone. The unblocking code is located
on the sim casing when you bought it. It will ask you to enter the code
and new PIN code 2 times but will completely block it if the limited
number of attempts is reached. You can just simply replace the sim and
the phone will work again normally.
Only the sim is blocked, not the phone. The unblocking code is located on the sim casing when you bought it. It will ask you to enter the code and new PIN code 2 times but will completely block it if the limited number of attempts is reached. You can just simply replace the sim and the phone will work again normally.
