Take and spray wd40 on the latches and open close the door a few times and that should fix the problem that is what was wrong with mine. That took care of problem if that doesnt fix it the senors need to be replaced in the latch
I have a 2003 F-250 Crew cab short bed. My door ajar light stays on all of the time and when I leave my keys in the ignition I have a constant ding. How do I find out which door is causing the problem, and what is the cheapest thing to try first?
A little wd-40 sprayed in the latches does wonders.
Hi, this is a CPU issue. i would advise to take this vehicle to the dealership for repair.although, you could have a door pressure switch that may be malfunctioning. i doubt it. i would take it in for a CPU look.
My 2002 F350 had the same problem.key fobs didn't work or power door locks. Replaced the VSM (vehicle security module)$110 from Ford.located in dash board behind radio.it's a black box about 8x8.Fixed every problem I was having.
