I disassembled my hamilton beach brewstation deluxe 47334 for cleaning. When I put it back together, it started leaking. I think that I may have put the rubber stopper in the wrong place, but the top of the drip lever seems like the only place it should go. Please help!
There is a spring between the lever and the o-ring. It may have popped out when you cleaned the pot. That has happened to me before. The spring is necessary to hold the seal down until the lever is pushed.
How did you put it back together? The lever keeps hanging so it isn’t able to keep the spring in it’s place. The o-ring is the rubber piece in the filter, right?
Not an easy task. Need tiny fingers. Robotic surgery is easier. I took apart. I cleaned gasket. My engineer son had to save my sanity and get it back together correctly. And...it leaks. Hate to trash the whole thing for this tiny faulty part.
I have the same problem. I just called Hamilton Beach and gave them the model and serial numbers. They are sending me a new "gasket" complimentary but she said if that doesn't work, I'll have to order a whole new coffee tank.
I love my Brew station, however, water builds up below the coffee reservoir and if I forget to check it, it leaks all over the counter ! What can I do to stop this ??
