SOURCE: could not start the camera. Close other
Very gently take the back off of the Blackberry, slightly push in on the camera itself, reboot and the camera should work.
I found out the hard way selling my phone on eBay only to have it returned because the camera didn't work. It's a hardware issue and not a software issue.
If it's still under warranty, try and get a new phone, otherwise --problem solved.
SOURCE: my blackberry storm camera quit working. it says
if you hold down the blackberry button....(dots).....a menu will pop up ....those are all the apps the you still have open...go into all of them and make sure you manually close them out....choosing the close selection on the menu....and ur camera should come right back on...the same happened to me......
SOURCE: whenever i open up my
Hi, when a camera says could not open the camera close other application and try again ,means that either to much application where opened at a tie or the camera is corrupted.
First, scan through phone and see if unnecessary applications where open,If not, that means the camera is faulty and will eeed to be replayed.
SOURCE: when i go on my
when i go on my blackberry 8520 camera it says please close any other open applications and try again i turned off the phone than back on again but it says the same message
The phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
1 - Switch ON your Blackberry 9800 Torch with your current network/service provider's SIM card.
2 - Using the menu go to Settings Menu -> SIM card and press select.
3 - While holding the SHIFT key, type mepd.(NOTE: You may not see any text appear on the screen while typing mepd)
4 - You should now see the five locking categories listed.
5 - While holding the SHIFT KEY, type mep2.(NOTE: You may not see any text appear on the screen while typing mep2).
6 - Release the shift key.
7 - You will now be prompted to enter the Network MEP code. (it will also state how many attempts left)
8 - Enter the Unlock Code.
9 - Enter Return/Enter.
10 - The Blackberry 9800 Torch should then be unlocked.
