Hi Reyaz Welcome To Fixya You should go to mobile repairing center to unlock the memory card password.for that center's staff will unlock your nokia 2690 memory card password with the help of memory card password unlocker software.For that that staff will keep that memory card to the unlocker device then after he will unlock it within 2 to 3 minutes.That's it.don't worry.it will help you.if this solution will help you then don't forget to vote me at least 3 to 4 thumbs.
Steps to Unlock a Password Protected Memory Card of Your Mobile PhoneThe steps to unlock a password protected memory card of your mobile phone, is described below. Please follow the steps:
To unlock your mobile memory card, you need a file explorer. You may use FExplorer. To download FExplorer.
After finished downloading, install it to your mobile phone.
Insert the mobile memory card into your mobile phone. Remember, don't access the memory card through phone at this moment.
Run FExplorer and open the following location C:\system.
From the location C:\System, you will see a file named as mmcstore. Rename this file as mmcstore.txt.
Copy the file mmcstore.txt. and paste it to your computer. Now, open that file in notepad.
When you finished the above steps, you will find the password of that file.
Try standard code like 1234, 12345 or this code ( .adgj ). If still cannot unlock please put your memory on nokia phone model 9210 , 9300 , 9300i or 9500. It will remove the password
You do not have a password to unlock you memory card. The things you should do is to look at you and if you can see a small button you just only slide it to unlock. After that you can use your memory card now.
Hi there, I have a micro sd card from Nokia 5300 phone.But when i use the same card in Nokia 3120 Classic, the memory card has been locked but i did not set any password for the memory card...Can this issue be solved in nokia 3120 classic phone.Can the password be unlocked in nokia 3120 classic.........Please advise.....
i have nokia 5310. i cannot remove my password of memory card because i have forgot it. i have no idea about password.so it cannot be remove so please give me a solution
i have kingston's memory card(micro sd) i have never set a password. first when the set is alright it doesn't requires the password to unlock the memor card for my set but in others set it requires the password.but when i have given my nokia 6300 to the nokia care center,now it requires a password which i have never set.But the other mmc which i got with my mobile is working alright.So,please suggest me a solution to unlock my mmc.
