Breitling Chrono Cockpit 164-Pilot Wrist Watch Logo
Posted on Mar 13, 2009
Breitling watch winder rotations requirments
I have Breitling Chrono Cockpit. I need to by watch winder. Watch winders are from 200 to 2000 range rotations in 24 hours. I bought with 600 but watches stopped during the hignt time. Please recomend what brend and type (rotation quontity) watch winders I need for my watches.
Thanks
BM
  • Anonymous Nov 04, 2012
    Also make sure the watch is wound to start with. A winder will maintain the power not wind it from a stop.
    You can also check the ORBITA web site for the list of various movement requirements. CPS, CW, CCW etc
Anonymous
Level 1:
  • Contributor 24 Answers
  • Posted on Sep 19, 2009
Anonymous
Contributor
Level 1:
Answers
24
Questions
0
Helped
20964
Points
63
The watch should last 36 hours from fully wound. If your wearing the watch and using a watch winder and its still stopping, you have a problem with the mechanism. Get it serviced. (its probably just a clean and oil req'd)
Hi there, I just received a Kubrik Startbox for Christmas. Problem is my Breitling Superavenger seems too heavy for the winder. It starts to rotate then stops Please advise
Hello Damon Hiley
Beautiful Winder... (BUT RELAX)
It does not NEED to move constantly...
only enough the change position to allow the
self wind weight. to move a little... GENTLY.
Just like the normal movement of a PILOT...
HOLDING the controls steady...
(NOT cheerleaders)
Working as it should.
Carnac the Magnificent
Callisto Chrono B11045 stainless steel watch price new
You really should send it to Breitling via an authorized dealer. Breitling will be able to ensure the repair meets their standards including waterproofness.
1helpful
Watch flashes--why?
Flashing means low battery. Time to replace it.
My A24322 is not working. Pl let me know how to get this started. Is this an automatic watch or a winding watch?
Your watch is an automatic (self winding) watch which can be started by swinging it gently from side to side for some minutes to wind the spring up.
For details see their web site by inserting the following link into your search engine http://www.breitling.com/en/index.php#/models/navitimer/navitimer-world/.
Self winders rely on being used to keep them wound and operate best if used every day.
I don't know how to change the date on my breitling colt
Their web site does not give any user manuals but most watches change the date by pulling out the crown to position 2 (1 is the normal home position, 3 is fully out and 2 is inbetween the two) and rotate the crown to change date.
This quality of watch may require you to turn the crown wheel anticlockwise before pulling it out (extra seal).
If this does not work them go to http://www.breitling.com/en/index.php#/models/aeromarine/chrono-colt/ and using the menu on the left, locate their nearest service center and contact them. I fell sure that they will be only too happy to explain the procedure for changing the date.
1helpful
How long does watch run after winding
35 hrs if you do not move it at all. If you wear it continuously you will never have to wind it again!
4helpful
My breitling chronomat stops working even while its in a watch winder.
Every mechanical watch must be serviced within 2 - 7 years depending on what movement is is fitted.
Find your nearest watch repair shop and as for overhaul ( this is how we call full service of any watch).
Reasons for stopping can be numerous, but usually it is gummed oil, dust particles, and wear and tear.
Rate me, please.
2answers
I have breitling superocean watch.my problem is everytime i change the date the watch stops running. i have sent it back to breitling 3 times now and they say it is fixed but it stops working again. they...
you're not supposed to change the time at certain times if it is an automatic. I think any time after 8pm and before 4am (but check your manual). Apparently it messes up the mechanism. Maybe that's the issue?
Sep 06, 2008 • Watches
Top Breitling Watches Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Breitling Watch Expert? Answer questions, earn points and help others
