While Bar Chain oil will probably work, the owners manual (sitting in front of me) on page 9 says to "use SAE #30 motor oil". This is the owners manual for Models: M12510US, M15012US, M15014US, M15014AS, M30016US, M30016AS, M30016AW, M35016UW, M35016AW. Remington Electric Chain Saw
Regular chain and bar oil.don't ever use motor oil it's too thin and will burn up the chain and bar.
SOURCE: Remington electric Pole Chain saw - what type of oil do I use?
You need “Bar and Chain Oil”, available at hardware stores and home centers. It is SAE 30 with additives to make it adhere to your bar and chain.
An excerpt from a Remington manual follows (edited).
FILLING OIL TANK
1. Remove oil cap.
2. Fill oil tank with SAE 30 motor oil if the temperature is between 30 & 75°F.
• Colder use SAE 10 oil.
• Warmer use SAE 40 oil.
3. Replace oil cap at once. Tighten oil cap firmly for a good seal. This will avoid oil seepage from tank.
4. Wipe off excess oil.
• It is normal for oil to seep when saw is not in use.
• Empty oil tank after each use to prevent seepage.
Some manuals go from page 6 to page 14. This one is very good.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/113005-01D/113005-01D_OM.pdf
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
SOURCE: I have a remington electric pole saw. I need to
the oil lubricates the chain & bar.you can buy bar oil where they sell chainsaws,but any5w-20 or 10w-30 is cheaper and just as good.use that 1/2 pint left over when you changed the lawnmower oil!
Use regular bar/chain oil available from home centers, hardware stores, and saw shops. Good luck!
