When i follow the instructions to upgrade the firmware on my router (WGR614v9 firmware version-V1.0.11_1.0.1VGUK) to firmware version-1.2.6, it wont allow it. It says "invalid file name or path" but i followed the procedure 20 times and still nothing. It says download file to computer then upload to router but it will not upload to the router, any help please.please.please
I was having the same issues too. I followed the steps dotted all over the internet and was getting stuck in exactly the same place. No matter how hard I tried, I just kept getting the 'invalid filename' issue.
Eventually I figured it out - the way that Netgear/Virgin have blocked firmware updating is to break the filename checking page so it doesn't accept any files. What we need to do is bypass the filename checking code so that the firmware upgrade system can then handle the file, and we're going to do this by manipulating the web page using a tool called Firebug.
Here is the solution:
1) If you haven't already got it, install Mozilla Firefox 3 (there is good reason for this - I'm not just shamelessly plugging it! :P).
2) Install the 'Firebug' extension for Firefox from https://addons.mozilla.org/en-US/firefox/addon/1843 and restart your browser when requested.
3) Navigate to your router's admin page, and fill in your login details (if you don't know them, it's likely to be the one written on the bottom of your router).
4) Navigate to the router upgrade page (the one where you select the firmware to upload' and select the location of the firmware file, like you would normally. Now, instead of clicking the 'Upload' button, press F12. This should bring up Firebug in the bottom quarter of your screen.
5) Now, click the button at the top of the Firebug panel and then click on the 'Upload' button. This will bring up the code for the upload button, where it does the filename checkinfirmware update for netgear router - b5b0399.jpgok like this:
6) It looks like Netgear have actually stripped out the real checking code so it can't be used, so we'll need to fool the page into thinking everything's fine and dandy with the filename so it can update the firmware. Click where it says "return checkData();" and replace it with "return true;".
7) Finally, click the upload button. The router should now accept the file and start updating.
And hey presto! You have a non-nargled wireless router with the latest firmware!
This worked for me took a bit of navigating to find the offending checkdata() but it did work in the end so thanks for the post!
just change the filename to match the router and version number with an img file extension. for example on a netgear WRN2000 router put the file name as WNR2000-V1.2.3.7NA.img i had the same problem with invalid file name and this cleared it up.
Use only INTERNET EXPLORER for firmware update as it wont work with mozilla firefox, mine updated perfectly fine
Just change the filename to match the router and version number with an img file extension. for example on a netgear WRN2000 router put the file name as WNR2000-V1.2.3.7NA.img i had the same problem with invalid file name and this cleared it up.
1. Please verify the model and version of the router underneath it.
2. Go to http://kbserver.NETGEAR.com/downloads_support.asp and select the model of the router.
3. Please click on the appropriate version of the router.
4. Select the link of the latest firmware. Please click on the button Right-click and Save to Download. For the WGR614v9, here's the link ftp://downloads.netgear.com/files/WGR614v9-V1.2.6_18.0.17NA.chk
5. Save the file to the Desktop.
Note: Please perform firmware upgrade with wired or Ethernet connection only. Before you upgrade, write down all current settings as you need to enter them manually after upgrading.
6. Using the computer hardwired on the router, open any web browser like Internet Explorer or Netscape Navigator.
7. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
8. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
9. Click on Maintenance and then Router Upgrade.
10. Click Browse and locate the upgrade file in your Desktop. Click Upload.
11. Please wait for the router to reboot.
12. Reset the router.
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then please plug it back in.
WGT624v4 - Firmware Version 2.0.13
The complete information including easy to follow instruction how to download , how to install the software, how to upgrade etc....
Visit the netgear support website ,below is the direct website address
http://support.netgear.com/app/answers/detail/a_id/806/~/wgt624v4---firmware-version-2.0.13
hi and firstly, thanks..Yes i have tried to download to sub-directory but the same message appears..invalid filename please re-enter..this isn't just a little upgrade either, it's pretty huge..anymore ideas? it's appreciated
thanks for the help but thats what i tried before (and again and again) but it still says invalid filename please re-enter and try again..anymore ideas friend?
Sorry to say carl but thats how i have been trying to upgrade it, as that is the only way it says that i can. By right clicking and saving the 1.2.6 file to my desktop or sub-folder..i'm all out of ideas. I have not been using my laptop or wii or anything else wireless as i dont think my connection is very secure. It needs updating dont you think? once again carl, thank you..
oh and yes i'm in the uk. Leeds, england to be precise..
It says WGR614 version 9. I cannot find any other part that says another version of any kind
Thanks for your reply and sorry for my late reply..
It's WGR614v9.
I have tried everything to upgrade the router with no luck what so ever.
Yep, I', in the UK and yes my freind it is one of the "120" things now i've tried to do..lol
Thanks for your help though, much apreciated
Mine doesn't have that option my freind.. It would be a hell of a lot easier if it did..
It should have the option really, it would make sense.. Thanks by the way for helping.
What is the version number on the tag on the bottom of the router?
Do you happen to be in the U.K? There are specific instructions from the Netgear website on how to upgrade the router, but I can't tell if your V9 is able to be upgraded to 1.2.6. The link below will download a file that begins with WGR614v9 etc.
http://kb.netgear.com/app/answers/detail...
You right click on either the North America or the outside North America Tab and save it to some directory. Then log into the router from a wired connection and follow the instructions.
I hope this isn't one of the 20 things you tried to do, but let me know.
Carl
Mine says nothing about downloading it to the computer. I log into the router and perform the "check for upgrades" and it goes out, gets the file, and performs the upgrade in the same step. I have a Maintenance Router Upgrade tab that checks and downloads the latest and greatest (I have a v7 so yours may be different).
On some other brands of routers, you have to save the file to a known location, the desktop or create a subdirectory (because in Vista you can't save to the root directory) and then specify that location when you upgrade the firmware.
Try that and see if you can figure it out.
