Pride Mobility Victory 3 Wheel Electric Scooter Logo
Anonymous Posted on Apr 24, 2013
Ed light flashing
Light flashing but batteries are good. now power to motor or brake. what else does the flashing red light meen.
upallhours36
Level 1:
New Friend:
  • Contributor 36 Answers
  • Posted on Apr 28, 2013
upallhours36
Contributor
Level 1:
New Friend:
Answers
36
Questions
0
Helped
8077
Points
80
I think you might try the reset switch on the battery pack
I have a ezgo p3211 power wheelchair just put new batteries in it and lights are flashing and it won't drive.
The lights flash in a systematic sequence which reveals an VSI error code. Count the number of flashes.
1. Battery needs charging
2. Left motor bad connection
3. Left motor shorted
4. Right motor bad connection
5. Right motor shorted
6. Unplug battery charger
7. Joystick fault. Make certain the joystick is in the neutral position (centered) before turning on the controller
8. Controller fault. Check connections
9. Parking brakes bad connection. Check connections to parking brake, motor and controller
10. Excessive voltage. Check battery charger connections.
2answers
Saeco vienna delux (analog)
meens its not getting right amount of power change the power suply in take to a local lite shop they could show u how if u dont know how ok thx nick
1helpful
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Flashing green light
hello,are you sure that you have not left your camera flash on,and virtually killed off the battery?as the zig zag icon usually refers to mostly flash related aspects of most modern cameras,all cameras need a certain base level battery power,before they will switch on for use,but may well display all manner of icon's and oddity's when the power is all consumed.hope that helps, cheers.
2answers
Invacare MKIV R11 Flashing lights
One of the most common controllers, codes to help you and others.
VSI & VR2 Joystick error flash codes:
1 RED BAR:
Low Battery Voltage The battery is flat (more likely).
Or the battery has a bad connection (which is unlikely)
2 RED BARS: Left Motor Disconnected The left motor is disconnected. Check all the connections for physical disconnection or corrosion or burning usually caused by the salt poured onto the roads every winter.
3 RED BARS: Left Motor Wiring Trip The left motors wiring has a short circuit. Check all connections and leads for wear and chafing between the left motor and the battery cables or chassis
4 BARS: Right Motor Disconnected The right motor is disconnected. Check all the connections for physical disconnection or corrosion or burning usually caused by the salt poured onto the roads every winter.
5 BARS: Right Motor Wiring Trip The right motors wiring has a short circuit. Check all connections and leads for wear and chafing between the right motor and the battery cables or chassis
6 BARS: Activated if you turn on your wheelchair with an external device like the Charger still connected.
7 BARS: Possible Joystick Trip, Make sure that the joystick is in the centre position before switching on. If you still get this when switching on then joystick is probably faulty.
8 BARS: A control system trip. Make sure that all connections are secure and if so the power module or control pod is probably faulty. Test by substitution of known good one.
9 BARS: The parking brakes have a bad connection or have a failed solenoid, or any lever or switches that disconnect drive for pushing the chair manually may be pulled or switched.
10 BARS: Over voltage detected. This can happen with a bad battery connection although unlikely. More likely your battery charger is faulty and is overcharging your batteries quite severely.
1 BAR to 10 BARS and back in a "ripple" every few seconds. Joystick not cantered when turned on. Switch off and try again.
1 BAR to 6 FLASH every few seconds. System Asleep. Switch off and back on. Time before sleep can be adjusted or disabled in programming
Hope this helps, If so please click the "Yes" button
Regards, Mark.
2helpful
Plantronics Voyager Pro bluetooth headset seems to be stuck in pairing mode. The lights flash red and blue, my motorola droid will show paired but not connect ed. If it does connect at all it will drop...
You want to turn off the power to your headset and turn off your phone. Remove for 30 seconds the battery from the phone and reconnect. Then follow the pairing instructions found on pages 4-5 in this link for the Plantronics Voyager Pro+.
Good luck from Headsets Direct!
We have a CTM HS-2800 power wheelchair that has 2 red, 2 green & 2 yellow lights that come on flash 8 times and then go off. What might be the problem when this happens?
You have a module problem:
Evaluate your batteries. 12v Single or 24 together.
Flash codes:
1. Stall Timeout, Joystic out of neutral
2. Battery Voltage too over 32VDC hi or too low under 17VDC
3. Left motor Fault
4. Right Motor Fault
5. Left Brake Motor fault
6. Right Brak Motor fault
7. Shark Control Module Faul
8. Power Module Faul
9.Shark Module Faul
1helpful
Ctm hs 2800 turn on key light come on and blink 7 time then go out push joystick foward motors kicks in and out and lights blink 7 times and then frist red light keeps flashing
3. Left motor Fault
7. Shark Control Module Faul****this will be your problem***
9.Shark Module Faul
Contact me Direct 909-590-1388 x115 CTM HOMECARE OFFICE
No power to motors joy stick does not woirk
Hi. If you count how many lights were flashing and let us know then I can look up that fault code and tell you what it is. Do you have the free-wheel levers in the correct place? Check the motor and battery connectors. How old is the machine, are the motors or brakes faulty. The machine will not operate if the charger is still connected. Good luck. Neil.
Hitachi ED-S3170 Projector problem
If the bulb is under warranty then take it back.
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
