My step-father gave me his dell laptop and dell printer after he purchased new ones. He said that he had been using the printer on his desktop and it worked fine. After not using the a.i.o. printer for some time, he bought new cartridges before he gave it to me. He said that it wouldn't print now. Once I got it home, I uninstalled the printer that he had installed on the laptop. I then reinstalled the a.i.o. printer, but I kept get the "cartridge error" message. I checked my cartridges and they seemed fine. I didn't have time to mess with it as I was running late for work. A couple of days later, I decided to mess with it again to see if I could figure out what was going on. Now the "cartridge error" no longer comes up and the printer feeds paper through. However, the pages are blank. I don't really know where to go from here as the user manuel does not cover this problem.
SOURCE: Dell 810 All-In-One InkJet Incompatible Ink Cartridge error message
Well, first off ,it's dell's fault, not yours. Even Official Dell cartridges are temperamental at best. The cartridge error you are explaining is common with Dells. They even have what's called a marriage issue, meaning the cartridge will work in only one single printer. However, I'm not sure how to fix it. Sometimes, you can install a new one and the other cartridge you never touched gives you fits, and goofs up. I'd say get a new printer. Dell is increasingly getting more stingy with their ink, and truth be told, I don't think their quality (*lexmark makes dell, so stay away from them too) matches HP or canon. If you want the best cost per page, get a canon that has individual ink cartridges. They are easy to refill, and print a great picture. You pay more $$ up front, but you'll save a ton in the long run
SOURCE: Black stopped printing out. Dell 922 all-in-one ink jet.
HI thanks for that and i will try it.
SOURCE: A10A940 Dell Printer
Our black ink quit printing, cleaning did not help. I finally got it to print by selecting:
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
SOURCE: dell a940 all in one printer
hmm..ok..if the test page is good, then it's in the drivers. get new ones, remove old ones first, re install try again.
SOURCE: Dell A960 printing blank pages
I just sprayed windex on bottom of cartridge several times and wiped with paper towel until dark streak of black appeared. Then I dried off cartridge and replaced. It works now. Must have been clogged.
My 948 all in one printer will only print blank pages.
How can I rectify this problem
