Nike Imara Run WR0075-014 Wrist Watch Logo
Posted on Mar 13, 2009
Beeping watch my watch beeps every hour on the hour there is a little black bell displayed next to the date my watch also for some reason now beeps every time a button is pressed and when i first got it that never happened how do i make it stop?
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Aug 17, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2314
Points
When in the 'TIME' mode, Press the button top-right of the face - the bell should disappear, and the hourly beep, and the buttonpress beep.
Jim
1helpful
My watch beeps every hour on the hour, how do I silence it?
Hir Mode button till get to ALM. then after it switches to SIG mode depress ADJUST button once. This will remove the little bell symbol and hence the hourly alert.
1helpful
9answers
Watch Problems
PROVIDE US HERE THE WATCH MODEL..
AND ALSO PROVIDE A DETAILED PICTURE IF POSSIBLE...
Sep 17, 2008 • Watches
9helpful
3answers
My G-Shock doesn't beep every hour, how do i get it to do that?
To make it beep every hour you must first put it on the alarm mode. Then, press the START-STOP button until a little bell shows up at the left. Hope it helps!
2helpful
How do u get hourly beep to turn off on digital watch
To set time, date, and options:
1) With time and date showing, press and hold SET.
2) Current time zone (1, 2, or 3) flashes. Press + or to select time zone to set, if desired.
3) Press NEXT. Hour flashes. Press + or to change hour (including AM/PM); hold button to scan values
4) Press NEXT. Minutes flash. Press + or to change minutes
5) Press NEXT. Seconds flash. Press + or to set seconds to zero.
6) Press NEXT. Month flashes. Press + or to change month.
7) Press NEXT. Day flashes. Press + or to change day.
8) Press NEXT. Year flashes. Press + or to change year.
9) Press NEXT to set options. Press + or to change value and then press NEXT to go to next option. Press DONE at any
step to exit and save settings. Available options are 12- or 24-hour time format, MM-DD or DD.MM date format, hourly
chime N, beep for button presses, customizable mode set (Select “HIDE” for unwanted modes – they are removed
from mode sequence).
Timex has two ways to find information about your particular watch. Some of these models only have a guide consisting of a few pages. If you don't have the manual, Try this link:
Complete Timex link site:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Now, look up the model number, or if you cannot find that, check the three-digit Module Number from the back of the watch. Click on it in the Module Table, and download a PDF of your watch setting-instructions/manual.
If you need further help, call Timex in Little Rock, Arkansas, phone 1-800-448-4639.
I hope this helps you. Thanks, Bill
I have an arnette digital watch, which beeps on the hour. I can't figure out how to switch this very annoying feature off! I can switch the alarm on and off by pressing the start/stop and reset buttons...
I have an Arnette watch as well and have long lost its manual. The model of my watch is AR 2201. Before it didn't beep, but after my move (where the watch must have been bouncing around a lot), it started to on the hour, EVERY HOUR. It has been driving me crazy. Hopefully this will help you, though the answer comes so late. For my watch, I pressed the ST/STP and RESET buttons (which both happen to be on the right side of the face) simultaneously. The watch beeped when I did this and I saw the little bell icon disappear! Good luck with yours.
Nov 22, 2009 • Watches
9helpful
Hourly alarm keeps going off, despite no alarm symbol showing
If the 2 dots (colon) on your time display are flashing you need to press START/STOP. I have had this problem for ages and it's been driving me mad, but just re-read the instructions for the 100th time and spotted it - it's the last sentence in the SET TIME-DATE section.
Hope that helps!
246helpful
7answers
GapKids Digital Watch - Need to know how to set
Light button is A
Mode button is B
Start button is C
Reset button is D
Standard Time Adjustment:
1) To set time, date, etc. press button B three times (assuming you start in standard time display mode)
2) Press button D until the area you'd like to change is flashing. (i.e.: minutes, date, day, etc.)
3) Press button C to change. Press once for one unit increment of change. Hold for 3 seconds for speedy advance.
4) Press D again until the next area you'd like to change is flashing.
5) At completion of changes press Button B to resume standard time display mode.
2helpful
I am trying to reset my T Touch watch from Tissot and can not find book. need to reset time and also how to convert from metric to US standards, like ferinhit and from meters to feet.
SET TIME:
1. Activate Crystal
2. Tap center of screen until digital time comes up
3. Press and hold top button (+) until watch beeps, display will be flashing
4. Use + and – key to adjust time. If several hours off, hold appropriate key and
after first hour passes, only the hour hand will move.
5. Make sure the digital display shows A or P for AM or PM
6. When finished, touch center of screen again.
SET DATE:
1. Activate Crystal
2. Tap center of screen until date appears
3. Press and hold top + button until watch beeps and display flashes.
4. Use + and – buttons to change date to correct one.
5. Make sure to set time first, if you set date first, you run the risk of the date
changing at noon rather than midnight.
1helpful
Alarm and hour beep
On your watch ( in the digital area) there has to be a a bell looking design and or a ))) That show that your hourly chime is on. You have to either push two buttons at the same time OR go to the alarm mode on you watch and push any button besides the mode button, one of the buttons should take that little bell or))) off you screen. If this dosn't work, PLEASE let me know and I will research this a little more.Good Luck!!!
28helpful
2answers
Adh1583
go to mode and scroll to select alarm setting.Look at the display of your watch if you see the icon of the bell there,it means its alarm hourly,if you off the alarm the bell icon of the display will gone,so it will not alarm..
hope this may help;
don't forget to rate;
Top Nike Watches Experts
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
ADMIN Eric
ADMIN Eric
Are you a Nike Watch Expert? Answer questions, earn points and help others
