Vista is already included with drivers of diffrent branded printers (with different models as well).
So Follow the instructions below serially:
Go to control panel
> then go to printers
> add a printer
> add a local printer
> use an existing port
> this step is the main part. You will see diffrent manufacturers with different models.So look for your printer. If it is not there then you will need the CD which was given with your printer.insert the Cd then in add a printer window select Have Disk and select your CD location
> Then Next & follow the remaining steps
that's it! You have installed your printer :)
But if you don't have the CD then you will have to look for the driver on the net.
It won't work if you didn't install the printer software??
