Blower was running good when fuel tubing broke replaced tubing but not sure which tubing has the fuel filter. Once I get enough gas in carb. the blower will start and run just untill the gas is out of the carb. then I have to pump again. The pump up is very small due to the bulb being small to refill after each pump.
SOURCE: ryobi fl 1500le leaf blower
Here is a link to one of my Tips:
www.fixya.com/support/r6081786-trimmer_weed_eater_only_runs_10_15
This should solve your problem.
Jim
SOURCE: I have a Weedeater fl
Simple solution your weed-eater has a Walbro carb buy a rebuild kit and rebuild the carb and it will run like new, don't touch any screw settings on the carb. You can purchase from your local repair center just give them the number on your carb and they will give you the correct kit. Go to smalleng.com they have a video on just this issue. Good Luck.. Don't forget thumbs and feedback.
carb diaphram is probable bad.
SOURCE: WeedEater FL 1500
if the choke needs to stay on to run it then there is a plugged jet in the carb
