My Whirlpool Gold GI0FSAXVY keeps freezing items in my pullout drawer - the one that is just above the freezer. It freezes everything! Tired of wasting money on fresh veggies and fruit to get frozen cucumbers, carrots, ...just about everything that goes into the drawer. I have it on the recommended setting at 38 degrees.
SOURCE: freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
SOURCE: fridge is freezing
there is a way to adjust it but its very difficult..best to just replace it. the thermostat that is.
SOURCE: Fruits & Veggies are freezing in both lower frig compartments
Good day,
This problem appears in spades this time of year, every year.
The problem becomes more severe when the temperatures in the house cools down and is made even worse if the usage of the machine becomes lighter.
It occurs when the machine is off, not on.
There is an open vent, near the bottom, between the freezer compartment and the fresh food compartment. This opening or vent is necessary when the machine is running, so that the air pumped into the top of the fresh food section, can return to the freezer compartment. This is by design.
Now,
When the machine is off, the zero degree air from the freezer compartment. can drift into the fresh food compartmnet and drop the temps near the bottom to below freezing.
Off time increases substantialy at this time of year.
Some have even recommended turning the controls colder to offset the problem, but I've no proof it works well, or even a little.
SXS and top freezer models experience it more than bottom freezer models.
SOURCE: Whirlpool Gold Side by Side (GD25DFXFW02) is over
the drain sump under the evaporator plate may be blocked or you may require a new defrost element
SOURCE: Our Whirlpool GI5FSAXVY refrigerator is
Hi, There can be many reasons why your
refrigerator is freezing your food. To see what could be happening
and to figure out how to possibly fix your problem. Take a look at
this tip which contains many of the causes and solutions to fix the
problems.
Refrigerator
is Too Cold and Freezing Food
heatman101
