Hey - first of all, thanks so much for any help you can provide. here's my Q. when i used to transfer music from my itunes to my regular ipod, i would just highlight the tracks from my music library and manually drag them into the "music" folder within my ipod folder. but why cant i do that with my iphone? the music library in my iphone, when it's plugged in to itunes, cannot be manipulated at all. but this is not what happens with my ipod. am i doing something wrong, or is this some difference between ipod and iphone? THANKS!!!!
This is easy:
On the summary page of your iphone on itune there are three options in the bottom third of the screen just above your capacity summary.
Make sure the button "Manually manage music and videos" is checked and you can drag and drop.
Make a new folder.....name it whatever...."iphone music"... make sure that whe your iphone is docked and it shows up under devices in itunes uncheck sync iphone automatically....check the box that say sync manually and sync checked items.....from your itunes libray choose the songs you want on your iphone...click and drag into your "iphone music" playlist.....when you have everything you want in the playlist go to your iphone under devices, go to music tab, then make sure the box is checked for selecting certain playlists...."iphone music" should be on there...check it's box....then sync....whenever you add more music to your main library put the ones you want into your "iphone music" folder then sync....if you want to remove music then go into itunes go to "iphone music" delete the song that you want removed then sync....this does not remove the music from main itunes library just your "iphone music" playlist.... I put about 200 songs on my iphone....listen at work....and then sync a totally different playlist of 200 different songs...about every two weeks...hope this helps...Also i have not had any problems with music from burned cd's or from file sharing networks...
The easiest way to manage this problem is be creating a Playlist called "iPhone" (or whatever you want to call it) and set the iPhone to only sync with that Playlist. That way you can drag music in and out of that folder (located in the sidebar of your iTunes window) to sync with your iPhone.
This problem is very easy to explain... Go to iphone (where your iphone's name is written) Then click musics.
There will appear Sync music.
Put a check on it and then choose The playlists or (is easier)
you select all playlists. There is the answer for a problem that was once mine :D
thanks for reading!!
Yes there is new digital rights management software on the iphone however there are ways around this. Take a look for more info here : http://hubpages.com/hub/iPhone_downloads
iphone Nova has it, its listed there. I use it and its great.
Did you sign up for the software there? Check my other posts this solved the problem for other people.
No it's not a farce, the problem is the way the iPhone handles DRM - Digital Rights Management. With the iPhone alot of pressure was put on apple to add these security measures by competing companies. SO you need a way around the DRM thats where the site comes in.
I case you want to transfer music the other way round: from iPhone to iTunes, try thishttp://www.from-iphone-to-itunes.com
In case you want to transfer music the other way round: from iPhone to iTunes, try thishttp://www.from-iphone-to-itunes.com
Find your solution from the list, Software & Hardware Problems Find Your Solutions for Apple Products:
Apple Iphone Smartphone
Codes:
Apple Iphone 3G
Apple iPod Touch Digital Media Player
Why not try this iTunes transfer ?it can transfer music from iTunes to iphone.it works well on all models of iPods or iPhone to transfer music and video from iPod to PC and iTunes. what is more,it can move your iTunes library to another computer.
I use this iPhone Transfer to inter-transfer music & video files between iTunes and my iPhone, works like a charm!
I needed to transfer music the other way round: from iPhone to iTunes
I tried this tutorial
It worked great for me
Try the audio ripper here http://www.daniusoft.com/audio-converter.html
First, merry Christmas! if you hope to
transfer files from your iphone to computer, iTunes cannot do it,
you can use some app to do that, as for me.
I used iStonsoft iPhone to computer transfer for one year, worth recommend.
but what system are you using ? PC or Mac ?
if you 're PC user, here is the method: how
to transfer music/photos from iPhone to coputer.
if you 're Mac user, sorry, I also am not familiar wtih Mac os.
hope it can help you !
i didnt see anything relevant on that page. where can i get the program you're referring to?
okay, i still dont know what in the world youre talking about. why is everyone being so cryptic? can someone please just tell me in like a couple of sentences how to fix this problem??? the suggestions i am getting are either incomprehensible, or require me to sign up to some bullshit service, or takes me only 1% of the way to the answer. i am beginning to suspect this site is some kind of farce. please prove me wrong, anyone...
So what is the name of the software / program I am supposed to be looking for to bypass the DRM? I know you said iphone Nova has it, but what is "it"?
i need help so i can daload music on my mpthree player
when i try syncing music a msg shows saying it would erase settings and replace with the new settings, clicked ok the iphone hanged... could not access sms, recentcalls nor keypad nor receeive any call only could call from my contact lists.
How do i sync music to iphone
I cannot sync my unlocked iPhone!?
I have an unlocked iPhone with a T-mobile SIM card in it. When I connect my iPhone to the computer, only the image viewer appears but nothing else. I cannot see iTunes or anything else (except for this image viewer) when my iPhone is connected to the computer.
Could you please help me to figure out how to put music on my unlocked iPhone?
Thanks.
I have the same problem
everytime i plug my iphone into the laptop and try to sync music to it i get the symbol with the usb and an arrow pionting to itunes and then it freezes on me its an unlocked iphone and im using a tmobile sim card please help ive tried everything for 2 weeks now any help would be nice
I created a library on itunes on my computer, but when I sync to my iphone, they do not transfer. What can I do?
I can't get music from my i tunes to my iphone
moving songs from itunes to my iphone 3g
my cd drive went out on the computer I sync with. I have another copmuter & was going to add songs to my iphone. How do you sync from one library to another with out erasing the current playlist on the iphone ?
