General Electric Stove/Oven/Range Chrome Timer Knob Set - WB3X459 Logo
Posted on Mar 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oven Lock stuck open before start of self-cleaning cycle
I startred a self-cleaning cycle on a frigidaire stove but I pulled on the oven door accidently before it locked shut and now it won't shut because the lock is stuck closed. I get a flashing lock light and a "dr" code on the panel when I try to set self-cleaning cycle again. I locked the oven door and set the self-cleaner. When the cleaning was done (I thought!), I tried forcing the lock on the oven door open. It would not open, and I kept tugging at it. Finally, I gave up until the next morning. The lock slid open like a charm, but now my oven door won't close all the way. Can you help me? Thanks!
  • thecoffee Apr 29, 2009
    I have the exact same problem right now with my Frididaire oven. I don't know what I did, but the lock is stuck out and the door won't close. It says "dr."
Anonymous
Level 3:
  • Master 8,197 Answers
  • Posted on Mar 12, 2009
Anonymous
Master
Level 3:
Answers
8197
Questions
7
Helped
3071327
Points
27242
Sounds like you bent the door where the lock is. You might have to replace the door.
Felix Delima
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Nov 03, 2017
Felix Delima
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1141
Points
10
Press the clear/off button for 8 sec
Frigidaire self-cleaning stove makes buzzing noise
How to Reset a Frigidaire Oven
  1. Press and hold the "Bake" button for six seconds until "0°" appears in the display.
  2. Enter the lower temperature at which you want to reset the oven.
  3. Press "Self Clean" to reset the oven's internal temperature to a cooler setting
https://www.hunker.com/13409693/how-to-reset-a-frigidaire-oven
If your Frigidaire oven has a manual lock, slide the lock-bar to lock the oven's door. If it does not have a lock-bar, the oven will lock automatically. 3 Locate the "Clean" button on the oven's control panel. 4 Press the "Clean" button to begin the cleaning cycle.
https://www.youtube.com/watch?v=DSYUj3yGybY
Oven Lock stuck open before start of self-cleaning cycle I get a code F9, a flashing lock light, a continous beep and a dr code on the panel when I try to set self-cleaning cycle again.
Thank you for your inquiry, Lucie!
From what you have described your Frigidaire oven lock is stuck open and you are receiving error codes "F9" and "DR". The "F9" error code stands for runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. The "DR" code means that the door is not closed or the door latch is not recognizing the door is closed. This could be an issue with your door latch or control panel. If the reset does not help correct your issues I would recommend having a professional technician out to perform a proper diagnosis and repair. Best of luck! -Matt
2answers
How do I get self clean to work on older fridgidare stove
Move the safety lock/lever at the top of the oven door to the right and press the self clean button on the oven control panel, it is an automatic cycle so it will lock the door from opening and then will proceed with the auto clean cycle. Good luck !
When cleaning the stove i touched my accident the
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
7helpful
2answers
Door locked after cancelling self clean option
Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
If you need more assistance let me know.
Mar 29, 2009 • Ovens
8helpful
6answers
Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
1helpful
2answers
Oven Door is locked and will not open
On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. Pull or push the rod to move the lock to the open position..
149helpful
15answers
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
1helpful
How to clean gas oven
hi,
use a 2 hour self clean cycle for light soils and a 3 hour cycle for heavier soils. The kitchen area should be well ventilated using an open window, ventilation fan or exhaust hood during the 1st self clean cycle. This will help eliminate the normal odors associated with the 1st self clean cycle.
when the controls are set, the oven door will lock and the “LOCK” indicator light will flash. DO NOT open the oven door while the light is flashing
Top General Electric Hardware & Accessories Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a General Electric Hardware and Accessory Expert? Answer questions, earn points and help others
