Question about Echo Power Blower PB-265L
Ignition coil. how can i be sure my problem is the coil and not something else last year worked very well and there were some times it took me a little more effort to start it. one thing is i forgot to drain the leftover gas.
  • Echo Master
  • 7,482 Answers
Hi luis
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in and be sure to install it in the same position
Normally the clearance is around .10 thousandsands
Also write the measurement down on a piece of paper for later reference, this measurement is critical to starting of the engine later.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
You can also try to lightly sand the module metal face to increase the possibility of ignition of the old module before replacement.
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Also be sure to check and clean your spark arrestor in the exaust,if you have one installed on your engine.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Apr 23, 2013
6ya staff
SOURCE:
I have a Maytag dryer model DG412 that recently stopped heating. I replaced the igniter and it worked for a few minutes then stopped again. When I removed the igniter it broke into pieces.
Usually if it heats for few minutes then doesn't relight one of the coils has gone bad. They come as a pair as you know somake sure you replace both. You have done everything right so far... You do have bad coils though.
Dec 09, 2016 | Maytag Dryers
Ignition control module
computur
computer error
Nov 23, 2013 | Buick Cars & Trucks
My 2007 Ford Taurus wont go forward or reverse
Your engine is shot, It is staying good buy to you.
Oct 30, 2012 | Ford Cars & Trucks
Ignition Coil
Look into the crank sensor or an ecu that needs repairing. Those two, being bad, will cause a no spark condition in your jeep.
Mar 31, 2012 | 1993 Jeep Grand Cherokee
I'm thinking the ignition coil is the problem but not sure. i checked the ignition coil but no electricity what do you think?
theres no spark from the coil. okay, what year and make and model is this car and last what size engine, you may have a bad coil but hard to say without knowing the car, this may be due to a bad coil or crank sensor and last broken timing belt all depending on the make.
Oct 17, 2011 | 1999 Hyundai Accent
I have a ford escape 2002 i was driving on my way to work it started jerking and then stopped i have to tow it to my house cos the car service was already closed by that time. So later when i took it to...
Your ignition coil misfires, most likely ruined the converter
before they reached 12 to 14 years of age
You need all ignition issues resolved,coil issues resolved,
new converters,new O2 Sensors etc
You have no choice & can expect to pay over a $1000
Unless you have the vehicle scoped a couple times a year
& data looked at, your going to keep getting into what your
have now. You just drive until it breaks down, That is what
everyone does & it won't work on todays technology.
Your intake manifold has to come of just to do spark plugs
& coils on that motor,which is a MAZDA
Jun 07, 2011 | Ford Escape Cars & Trucks
No spark at plug
27 years of service for an ignition coil is close to amazing. Recent machines using magneto-type ignition systems are doing well if their Chinese-made coils last a couple of seasons.
I'm pretty sure that is what has failed in your Toro and I hope you can get a replacement from really old stock so you aren't doing this again in a couple of years.
A tip: Use something to measure the gap between the magnets of the rotor and the core of the current ignition coil before you remove it and set the gap the same for the new one. Some setups are fussy about that gap.
Jun 18, 2010 | Toro Lawn Mower With Toro Power Tools
Problem with starting my 2003 dodge ram
My father has the same problem with his 2001 Chrysler Sebring, the key will go into the ignition switch but wont turn. Called the dealer and seems the tumblers inside the ignition have gotten stuck, the solution... put the key in the ignition and tap it gently with a hammer (plastic tip if you have it) and it worked fine. Not sure what the guys at Autozone are pull but on a Ram 5.7 Hemi there are individual coils, not one, I should know I also have a 2003 Ram 1500 and have changed the plugs (not fun)... I have a code scanner (Hypertec) and when I've gotten a check engine light I check it with the scanner. Turned out mine had a problem with the air sensor in the intake. $15 part fixed the problems. Good Luck.
Apr 18, 2009 | 2004 Dodge Ram 1500
Problem starting my 2003 dodge ram
no if you took it to autozone obviously you have a good ign coil.im sure you have tried turning the wheel at the same time you turn your key. other than that i would replace the lock cylinder and key.
hope2help shack
2001 Hyundai Santa Fe Ignition coils & EGR Valve
Well I went ahead and took a go at changing the coils, plugs and wires yesterday. It literally took maybe 15 minutes and my hands didn't even get dirty. This is something that the auto place wanted to charge me 650 to do. I spent 200 on parts. I didn't realize the coils were the things sitting on top of the spark plugs. I think my 4 year old could've done it. All I had to do was unbolt the coils detach the wires and then replace. It was too simple.
Apr 17, 2009 | 2004 Hyundai Santa Fe
Echo Power Blower PB-265L Logo
147 people viewed this question
Top Echo Garden Experts
Mike
Nick Olsen
choprboz5
Are you an Echo Garden Expert? Answer questions, earn points and help others
