SOURCE: Help!! Sanyo VPC-E760 Digital Camera driver for Mac OSX
the driver is not separately available for Sanyo VPC-E760
SOURCE: Need users manualnfor sanyo VPC-T700 digital
Get the manual here >>>>>>>>
http://sanyoservice.com/pdf/images/VPC-T700.pdf
This manual will show as an on-line PDF, when its loaded up all you have to do is save it to your computer.
Regards
SOURCE: Sanyo VPC-S1080 turns on and
See if the menu has a battery type setting. Some cameras have the ability to use different battery types (alkaline, Ni-Cad, Lithium, ect) and have power management presets to accurately indicate a low battery condition. If you are set to one type an install another, a false reading would result.
Testimonial: "Although the recommended fix did not resolve the issue, it was a great help as a learning experience"
SOURCE: When I turn on my new Sanyo VPC S1285 camera it
When I turn my sanyo vpc-s1285 on it stays of the blue Sanyo Screen Can you help me fix this?
SOURCE: my sanyo vpc 51285 doesnt record any sound
Hi, try to open the camera and check the 'mic' if its working or not.you need todo is desolder and resolder the connection of the mic. in that case you will know the problem.
good luck
