Westinghouse Electric LD4655VX TV Logo
Anonymous Posted on Apr 22, 2013
I have a Westinghouse LD-4655VX and when I turn the TV on after about a minute or two the screen start flashing/blinking a white screen every two seconds, it doesn't matter if it's hooked up t
Bill Heronemus
Level 2:
Sergeant:
  • Expert 308 Answers
  • Posted on Apr 22, 2013
Bill Heronemus
Expert
Level 2:
Sergeant:
Answers
308
Questions
7
Helped
129281
Points
612
It's likely a loose solder connection that acts up after a short warm up period or defective capacitors on one of the circuit boards.
  • Anonymous Apr 22, 2013
    Would it be best to replace the circuit board? I really don't want to put too much money into it, I would rather take that money and invest in another TV.
1 Related Answer
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Jun 17, 2011
SOURCE: My westinghouse ld-3255vx tv will
The standby power supply is working but the rest of the set is inshutdown mode, it can be due to bad power supply (bad caps, etc.), backlights inverter board, main board. You will have to do in-depth troubleshooting and please read my guide to understand how thw LCD TV works.
It will need parts for sure.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
How do you turn on westinghouse ld-4655vx tv with no control? Has A Control Panel Painted But I Do Not See Buttons Anywhere !
Buttons will be underneath on the side/side back or they will be soft touch buttons on the front.
2answers
Ld 4655vx fuse replace
I just fixed this same problem and it wasn't a fuse. I made a video showing how to troubleshoot and fix it.
1helpful
Get code for Westinghouse model LD-4655VX
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
2answers
Westinghouse LD-4655VX Power on fine, nice picture, but around 5 minutes turn off self it
hi. the led tv turn off itseft aroun 5 minutes was complete shut off or another ?? need more data???
1helpful
Westinghouse LD-4655VX Power on fine, nice picture, but around 5 minutes turn off self it,
If the set is still under warranty, the power supply board is going bad. If not you can replace it yourself. It's not that big of a job. You can find the parts you need at www.shopjimmy.com
Westinghouse LD-4655VX won't turn on - is my power supply broken
I just fixed this problem and it wasn't the power supply. I made a video showing how to troubleshoot and fix this problem.
Tv won't turn on Westinghouse ld 4655vx
I just fixed this problem and it wasn't the power supply. I made a video showing how to troubleshoot and repair it.
Our westinghouse ld 4655vx just shut off bye itself and won't turn back on
Check and replace its main power regulator board. It is faulty. Not working.
WESTINGHOUSE LD-4655VX CODE FOR XFINITY REMOTE
The Westinghouse LD-4655VX TV has code compatibility with Sony TVs (http://westinghouseelectronics.com/wp-content/uploads/2012/06/Remote_Codes_2012.pdf). I accidentally discovered that the Sony TV remote RM-YD040 works with my he Westinghouse LD-4655VX (because I have both TV sets).
Top Westinghouse Electric Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Westinghouse Electric Televison and Video Expert? Answer questions, earn points and help others
