Use the provided link for fuel/gas mixture.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
SOURCE: McCulloch Chain Saw Mod.600133C, need to know the proportion of
oil, gas ratio is 40 to 1 A plug for small gas engines will work
SOURCE: Gas Oil Mixture
Fuel Mix: Add 6 oz. McCulloch custom lubricant or 1 PT. S.A.E. 40 (16:1) to 2 U.S. Gal. Regular Gas
SOURCE: i need to know which
There really is no exact type of oil that goes into the chain and bar oiler. Each manufacturer usually makes their own, but any chain and bar oil will work. It is a thicker type of oil unlike a motor oil. Just ensure that the bottle says "bar and chain" oil
Check your manual for the proper gas-and-oil mixture. For almost all modern two-stroke engines, a 50-to-1 mixture is recommended. That requires about 2 1/2 oz. oil for every gallon of gasoline.
Use only two-cycle oil for your mixture. This oil is made especially for these engines and can be purchased at gas stations, hardware stores or any other place where you buy regular motor oil.
Pour the proper amounts of gas and oil into a fuel can. Shake the can well to mix it.
Label your gas can with the mixture ratio. You can use the same mixture for other two-stroke engines.
Shake your fuel can thoroughly every time you refuel. After a while, the oil will settle out of the gas, and shaking it up ensures that the oil and gas are properly mixed again before you put the fuel into your chainsaw.
