Yamaha 5.1-Ch. Surround Sound Home Theater Speaker System Logo
Rob smith Posted on Apr 21, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Psw111 hook up to vsx-522 subwoofer
Have a pioneer vsx-522 receiver trying to hook up a Polk psw111 subwoofer receiver has sub woofer pre out tells me to hook it up to LFE IN but my sub docent have that input only has line in left and right ??
Steve K
Level 3:
Genius:
  • Yamaha Master 1,054 Answers
  • Posted on Apr 22, 2013
Steve K
Yamaha Master
Level 3:
Genius:
Answers
1054
Questions
0
Helped
574215
Points
2865
Just use one of those jacks. Then turn the frequency select dial all the way up. This will work just as well.
2 Related Answers
Anonymous
  • 8546 Answers
  • Posted on Jul 31, 2011
SOURCE: i have a yamaha nx sw150 subwoofer that i want to
Parts from all-in-one packages like this aren't inended to be pieced out to other applications. Proprietary connections are a huge clue and disincentive.
http://www2.yamaha.co.jp/manual/pdf/av/english/sys/NX-P150_e.pdf
A look at other Fixya queries gives this answer:
http://www.fixya.com/support/t4959365-yamaha_sub_woofer_model_nx_sw150
"I have this sub. The system connector jack needs a 12V DC signal to turn on. If you don't have a suitable Yamaha receiver with this connection, use any 12 V DC adapter with a 1/8 in mono plug (the tip should be positive)."
I imagine the subwoofer could be opened up and whatever circuitry is enabled by the Control signal could simply be jumpered "true" so it is always ON. That would mean the amp would be drawing power at all times, though.
Anonymous
  • Posted on Dec 15, 2012
SOURCE: I have a Yamaha sub woofer model NX-SW150 that was
Where does the 1/8 3.5mm mono jack get plugged into on the receiver? The RCA subwoofer output is already taken.
1helpful
4helpful
2answers
Pioneer VSX-822-k Subwoofer problem
I had the same problem. Dont know why the receiver set it up this way but grab your remote, go down to the lower right and select ch setup. Keep on pressing it till your receiver says SW. Then press lev+ on your remote to change the db on your powered sub.
2helpful
Power sub woofer is not working on my pioneer vsx-81txv everything is working all the speakers except the power sub connection at the back all i can hear is the hissing sound when i try to connect the sub...
Hissing? How loud? A sub isn't even capable of making high frequency sounds at normal volumes.
The Pioneer manual would tell you how to enable and test the subwoofer output.
Page 17 and the MACCV procedures on Page 33 (auto) or 43 (manual)
Loud humming sound from subwoofer PSW111 (specially(noticeable once AV receiver is off).
Check the connections from your reciever to your subwoofer. It sounds like they may be a little loose.
How to hook it up with sub dvd
Not sure what a "sub dvd' is but here's the manual. The Subwoofer Pre Out would provide a Line Level feed for a powered subwoofer, once it is configured to do so.
Page 14.
http://www.retrevo.com/support/Pioneer-VSX-D510-Receivers-manual/id/385ci969/t/2/
How do i connect a subwoofer to my vsx-9700s
on the back of the pioneer, you have a subwoofer preamp output jack, probably colored black, as opposed to red or white. stretch a rca cord between there and the red and white (or lfe) input of the sub. youll then have to check the amp setup menu and make sure it has the output activated. good luck
1helpful
Sub Woofer works but it won't when hooked up to the receiver
Yes, go to your menu then setup then speakers then subwoofer, it's probably in "LFE" it should give you the option of Sub, LFE, or Both. that should do the trick. Also check the crossover point and season to taste. While your at it; there should also be a setting for speaker level, toggle down to sub and adjust the sub out level, it's probably at it's minimum setting. Hope this helps
2answers
Sub Woofer Won't Work
Connect the input from the powered subwoofer to the rca jack on the VSX-409D labelled 'sub woofer preout'.
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
