Fisher and Paykel Aquasmart wl80t65c Logo
Misty higgins Posted on Apr 20, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fisher paykel aqua smart fault 49
Fault 49
Greg Stephen
Level 2:
  • Fisher and P... Expert 566 Answers
  • Posted on Dec 19, 2013
Greg Stephen
Level 2:
Answers
566
Questions
Helped
224535
Points
688
Fault code 49 is water valves, But the Aqua-Smart board is outputting the wrong code here, The Smart pump has blown the water valves fuse, A common thing in Aqua-Smart Machines.
The Smart pump has jammed with lint and caused over current to the board and taken out parts on the board that drive the pump.
Best to get a new/recondition board for your machine.
3 Related Answers
luisa_sgro
  • 713 Answers
  • Posted on May 16, 2011
SOURCE: error code 49 on fisher and paykel 8kg aqua smart
Hi just read your posting.Error code 49 means the computer has measured a voltage from the valve diagnostic circuit that indicates the cold valve is faulty.Would you like help in confirming that the cold valve is faulty?You need an electrical test meter.Please reply and I can guide you thru the testing procedure.Looking forward to your reply.
Anonymous
  • 10 Answers
  • Posted on Jul 11, 2010
SOURCE: fault 49 smartdrive
Hi have had this problem on phase 5 grey controller, on the controll board near where the valve hot and cold wires are connected you will see a small usually blue resistor value approx 5ohms this is probably open circuit replace it check your water valves before reconnecting I was fortunate enough to have plenty of spare valves so I just replaced both valves as I suspect a faulty one may have damaged resistor machine has been working fine for some time since
richroth
Richard Roth
  • 9472 Answers
  • Posted on Apr 25, 2012
SOURCE: fisher@paykel aqua smart washer shows fault code49.
Fault 49 on F&P agitator models is bad cold water valve or wires on it disconnected.
Fault 49
The main board is displaying the wrong error
for the problem your machine has.
Fault 49 is water valves error.
The most common problem with AquaSmart is pump faulty
and damaged your motor control board,
Pump and motor control board need replacing.
Error code 49 f&p aqua smart wl80t65c
49 is a cold water valve fault. test the valve for voltage while filling, it should be recieving 24V. if not, the problem lies with the motor controller.
Fisher paykel aquasmart fault 49
Fisher and paykel toploader washing machine fault 49 water valves all show 60 ohms next step?
Fault code 49 is water valves, But the Aqua-Smart board is outputting the wrong code here, The Smart pump has blown the water valves fuse on it's overload, A common thing in Aqua-Smart Machines i always keep seeing,
Fisher@paykel aqua smart washer shows fault code49.
Cold&hot water valve dont seem to unscrew or do you have to buy the whole part
Fault 49 would most possibly be faulty motor controller board.
Not the water valves at all.
Error code 49 on fisher and paykel 8kg aqua smart washing machine, model number: wl80t65cw1. What does this mean?
I have an Intuitive Eco Fisher and Paykel top loading machine. When I turn it on a continuous beeping sound comes on with the message Fault Code 49 apearing on the screen. What can I do to solve the...
Hi just read your posting.Error Code 49 means your Cold water valve is faulty,Or your control module is faulty.To test this fault you need an electrical test meter to test the water valve coil for conductivity.Have you or can you borrow a test meter to check the water valve?Please reply on how you would like to proceed and I am sure I can guide you throe the steps needed to rectify this fault.Looking forward to your reply.
2answers
Fault 49 smartdrive
My paperwork says fault #49 is hot and/or cold water valve faulty. Check that the valve harnesses are connected connected correctly or check that the valve is not an open circuit.
1helpful
Code 49 and Manual Book
Fault 49 usually points to the cold inlet valve. I have come across many with this fault that the valve tests ok and it needs the motor controller replaced.
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
