Sony HXR-NX5E Camcorder Logo
Posted on Apr 20, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
E:61:30 error message
Rec / timecode flashing , error no E:61:30
Ivan Jimenez
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on Jan 03, 2022
Ivan Jimenez
Contributor
Level 1:
Welcome Back:
Answers
Questions
0
Helped
5354
Points
13
Please read. I took my Sony FDR-AXP35 Camcorder to be serviced for Error Code e61:30. The screen read that and I showed it to the technician. Within a week they emailed me confirming that exact code error and I gave them the go ahead with the repairs for THB 1132 (US$34). I called them yesterday after waiting two weeks on a job that they said would take less than a week. Now they are saying they found a new error code e61:10 and that the cost is THB 9585 (US$288). There is no way the camera computer would have read e61:30 and now they say is reading e61:10. Can anyone tell me if this is a clear case of malpractice? I will contact the Consumer Protection Board in Bangkok, but I need some technical support before I do that.
smith john
Level 2:
Scholar:
New Friend:
  • Expert 134 Answers
  • Posted on May 16, 2013
smith john
Expert
Level 2:
Scholar:
New Friend:
Answers
134
Questions
0
Helped
47612
Points
237
This error is
"Reset position detect error when stepper iris is initialized"
Turn on the power and set to T (telephoto) end by rotating the
ZOOM manual ring. While observing the iris blades in the
lens, turn on the power again and check the iris blades in the
lens work properly. Inspect the iris drive motor of lens drive
block (Pin qh to ql of CN6602 on the VC-582 board), when
the iris does not operate. Inspect the iris reset sensor of lens
drive block (Pin qd to qg of CN6602 on the VC-582 board),
when the iris operate.
if you need more help you can download the factory service manual from the below link:
http://goo.gl/Wt4pr
Good Luck
My tascam dr 100 gives a 'writing failed' file error' message and stops recording
Try using a smaller memory card. This only happens to me when using a 4- or 8-gig card. 2-gig and below, No error.
I m not able too send or rec. messages through nokia e62....even i have entered the required message center no. but no use ...even i have done formatting & flashing... but no use
There is a problem of ?timecode? with ?Sony DCR-VX2100 MiniDV?: Yesterday it functioned correctly, and this morning, when I support on REC, the ?timecode? begins again to zero, and when I stop filming it N...
This is most likely caused by a damaged or misaligned video drum and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
5helpful
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 • Motorcycles
16helpful
Sony Cybershot DSC-W90. Error message: Flash settings cannot be changed. What can be done about this?
You have set the the rec more into burst mode. You need to turn it back to single mode. The flash can not be used during the burst mode.
Oct 30, 2009 • Cameras
1helpful
Error message saying "supply rec. paper"
There is a small side tray on the right side of the machine,check if there are paper loaded in.
Error H U 11
U11 is a "dirty video heads" message. Either use a cleaning tape or have the unit professionally cleaned.
6helpful
Hunter 44360 thermostat
The message means the tstat was in recovery mode, I would suggest just disabling this function to prevent it in the future. Remove the tstat from its base and look on the back there will be a recovery switch just slide it to the other setting to disable the feature
Synchronize the DSR-45 as a 'slave' to an external unit with SMPTE Timecode
if i,m not miss understanding the problem is rec audio ng.if it,s, the posible cause are; 1;head dirty at the line of the tape causing data from head can,t write the tape optimal.for this problem you can clean the head carefull the head can easy broke., 2;if the picture having tracking posible the guide that bring the tape at the left doesn't fully at the track.for this problem at emergency you can try to push the left guide.
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
