The old administrator it of my compagny is out and i am the new one. i have a computer with a bios password and i don't know it
You can check solutions from this page
http://www.computerhope.com/issues/ch001302.htm
REMOVE BIOS PASSWORD
PC BIOS toolkit is a password removal/decrypt and BIOS settings modification/backup/restore.
http://www.syschat.com/download120.html&act=down
CMOSPwd - CMOS password recovery tools
http://majorgeeks.com/CmosPwd_d239.html
Using a computer with Internet access, download the files from these WEB sites and create a bootable CD disc to run them.
SOURCE: reset bios password
just the jumper position on the mother board pin 1 and pin 2 will be occupied just unplug the power cord and remove the jumper and put the in 2 and 3 then wait for 5 sec then put the jumper to original position and power the laptop
SOURCE: Same problem but have got acer travelmate 4150
Check on motherbord again you can find cmos cell it is look like round battery cell.
Then pull it for 10 minutes so all bios settings are defaults.
Also you can clear bios with jumper find jumper on motherbord it has 3 -pin 1-2-3 right now jumper is in 1-2 position set it to 2-3 position so your bios is clear.Then again set it to it's original position.
then it not ask for password.
Let me know if you need more assistance.
Thanks.
SOURCE: Acer travelmate 2410 phoenix bios setup utility
u got to replace ur BIOS. but der r ways to recover the BIOS password using default passwords, i need to get to know ur MOTHERBOARD build.
SOURCE: bios password for acer travelmate 2410
i have had just the same problem, i took my laptop apart removed the cmos battery its just to the side of the trackpack on top of the motherboard, but this did not work, HERE is the solution with out stripping the all the laptop make sure the battery is out and no power to the laptop all you need to do is take the plastic part with the power button on off and underneath you will see a small switch called SW1 move the number one switch to on then power up the laptop press F2 and there you go your in the bios, save all settings turn off put the switch back to where it was put you plastic facia back on replace the battery power up now press F2 and do what you want all is good
SOURCE: acer travelmate 4050 bios setup password, reset
hello, and I have a problem with Acer TravelMate 4050 and the problem lies in the total extinction of the system, namely when you turn on Windows light up when you enter and suddenly black screen and do not even think about blocking it immediately, but he remains on but do not think .... that is the problem?waiting for a response or contact id doi_ochii multtumesc advance ....
