This modem is configured for telstra networks and i need to use it on a third party network/service provider. please can you assist???
You need to contact your 3rd party service provider for the configuration settings for their network.
If you cannot change the settings on the Thomson modem then maybe the firmware is set to Telstra's network and cannot be changed. In this case you need to use the recommended modem suggested by your 3rd party service provider.
Hi you might want to reset the modem first to factory defaults then reconfigure the TG782T modem with the new ISP login (provided by your ISP),
SOURCE: cd drive not working can't
Try this: Router setup If you are using the cd that comes with the router, that is the problem. You do not have to use the cd. Go to the control panel and un-install the program that the cd installed. then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Try this:
Router setup
