WHEN I PRESS THE MENU BUTTON ON MY TV.
I GET THIS:
PROGRAM INFO
TITLE
LENGTH _ _: _ _ ELAPSED_ _: _ _
ALLL I WANT TO DO IS GET INTO THE MENU SO THAT I CAN THEN PROGRAM THE CHANNELS TO BE ABLE TO GET CABLE AND I CANT EVEN GET INTO THE MENU.
I EVEN TRIED TO DO IT W/UNIVERSAL REMOTE AND HAVE THE SAME PROBLEM.
DO I NEED TO MAYBE RESET MY TV???
FRUSTURATED... PLEASE HELP!
An original remote purchase will solve your problem.
Thanks for using FixYa!!
You need to buy an original replacement remote to fix the problem.
You can buy an original replacement remote from any of the websites below:
GE Remote Controls - Replacement Remote for GE
GE TV Remote Control New OEM
Replacement Remote Control 1-888-8REMOTE
GE TV REMOTE CONTROL Part Number 240961
Is that a universal remote... hit the button for tv... then the menu button on the remote the other that you are seeing is for your vcr likely
I have a couple questions for clarification:
What happens when you press the menu button a second time?
What happens if you try to use the arrow keys on the remote, or the +/- buttons on the tv after you press the menu button?
Is there a 'Program' button on the tv or your remote?
Please Check the Button both on TV and Remote. Check if there any stickey button.
Thanks,
PREM
Unplug the set leave it overnight plug it back in.
You will have to go to the options -----scan the channels --- in the menu.this will set the tv.but this can be performed only with the remote control.universal or orignal if you have.but scanning the channels will only set the tv as you want.it will automatically readjuist the system setup of the tv.
Try opening the TV and see if the menu button is defective.
It should be each to replace it.
Hi mariesprince,
Please provide the model number of your tv.
Is it a tv/dvd/vcr combo or a stand alone.
This problem should be able to be solved without having to buy a new remote.
Looking forward to your reply.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Try to push menu button several times it should redirect you to right menu. If not TV probably stuck on one of the menu options
Try to restart by unplugging. If no help you can get the universal remote for $1 in Dollar Tree or Dollar Store
OK, the best way to combat this is to order a replacement twin remote. All you need is the model number from the TV. Click here to purchase the remote.
the first link is broken, please use the second link labeled Click. thx.
Hi. i have found the remote you need. click here to purchase for delivery.
I you pressing the button on remote or tv itself. If on the remote, press tv button than menu. On tv, press the menu button twice. What you describe is a menu that looks like it's from vcr or recording device.
Try leaving the tv unplugged for at least 4 hours to do a master reset. I do believe any reset would help you. This is very strange. There might be another menu under a settings button or something. It's really to bad you don't have the origional remote.
I would try a reset.
I would suggest buying a remote. Even a universal if necessary. If you have tried unplugging the tv overnight and it still exists, than a remote may be your only other choice.
which brand is the television?
I believe a universal remote should fix your problem
How did this work for you? Did my suggestion work out for you?
It seems you turned on Timer in TV. Please check timer option and disable it if enabled.
Sounds like u are in a record program mode, u need the remote that came with the tv to access the input and set up functions, do u have the factory remote? unversal remotes don't have thes advanced functions.
Does the TV have a button marked "VIDEO"? OR ANYHTING THAT SAYS SETUP MENU? If not u need the correct remote to access the functions u need to set the TV up.
sounds like u are lost, have u tried calling the TV's customer support line for assistance, they can tell u exactly what to do or if u need a factory remote.
Look call the factory service agent, he will get the resolved in no time, why won't u do that?
* With the remote control in hand, press the POWER key to
turn on the Presentation TV.
** Press MENU repeatedly until the Setup menu appears.
*** Using the Up/Down arrow on the remote control, highlight
Auto Program on the screen
**** Press the Right or Left arrow to go to the Auto Program
menu.
***** Using the Up/Down arrow, choose either Cable TV or Off-
Air Antenna on the screen.
****** Press the Right or Left arrow to begin the Channel Search.
******* Press ENTER when the channel search is done.
Note: Auto Program finds channels being received by the TV
tuner
Cable will not work unless you subscribe to a cable service
OK.
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
[1] Press POWER button on the TV to turn it on. The Initial Setup screen appears.
[2] Press CH+ button on the remote control or on the TV front panel to start Auto Program, or press CH-- button to exit.
The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
To perform Auto Program again
1 Press"MENU" button on the front panel of your TV.
2 Press "RIGHT ARROW button to highlight Channel Menu.
2 Press DOWN ARROW BUTTON to highlight CABLE or ANTENNA AND PRESS [+} to select.
4 Press UP arrow or DOWN arrow to highlight On or Off according to how you connected your TV. Press [+] to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select
5 Press DOWN arrow button to highlight Auto Program. Press [+]to search for channels
6 After Auto Program finishes, press MENU button to exit.
OK
Programming channels automatically
Your TV can automatically detect all active channels and store them in
its memory. After the TV has stored the channels in its memory automatically,
you can add or erase channels manually.
To add channels automatically:
1. Press MENU, then press "left arrow" or "right arrow" button to display the SETUP menu.
2. Press "Up arrow"or "down arrow" until the TV/CABLE
selection is highlighted.
3. Press "left arrow" or "right arrow" button to highlight either
TV or CABLE, depending on which you use.
If you use an antenna, choose TV.
If you use cable, choose CABLE.
4. Press "down arrow" button until the CH PROGRAM selection is highlighted.
5. Press "left arrow" or "right arrow" button to start channel programming. The TV will automatically
cycle through all the TV or Cable channels (depending on which you
selected), and store all active channels in the channel memory.
While the TV is cycling through the channels, the message
"PROGRAMMING NOW-PLEASE WAIT" appears.
6. When channel programming is complete, the message "COMPLETED"
appears.
7. Press CH UP or DOWN button to view the programmed channels.
OK.
THANKYOU FOR YOUR HELP. NO I DONT HAVE THE REMOTE... SO I HAVE TO BUY A NEW REMOTE??
PLEASE HELP
MODEL 27GT624
ITS JUST A 27 INCH TV NO COMBO
