2 days ago freezer/fridge stopped cooling...fan on back of fridge works...ice build up along the bottom inside the freezer under the removable basket...unplugged fridge and plugged back in and can hear it kick on but no air blowing inside fridge and no water dispensing...had mother board replaced a year ago....any ideas?
If it has fan to deliver cold air, and it is not working, cold air is stuck on the begining. So your fan could be dead. And I suppose, that compressor is running all the time. Even compressor could stert freezing if fan does not deliver cold air in fridge. The other option is, that there is not enough gas in the compressor. In this case compressor vould not be freezing, but line, going out of compressor has to be hot, if it is not, there is no gas.
SOURCE: samsung fridge RS2630SH, side by side, icing up on freezer.
You have to pull out the sensor from the board and test with tester, both sensor should read the resistance of 10,000 to 20,000 ohms. The reading that you show is very low it means that the thermistor is out of range and need replacement.
SOURCE: SAMSUNG SIDE BY SIDE FRIDGE FREEZER
these appliances are a pain in the butt. fault with water dispensor is oprob that the water bottle at bottom of fridge is frozen. rise in temp is prob that defrost not taking place. not a diy unless you are experienced
SOURCE: Samsung RS2555SL humming noise
the freezer has gone on to test mode for some reason press and hold down at the same time the power cool and power freeze buttons for 8 seconds this will take it off its test cycle
good luck
phil
SOURCE: SAMSUNG RS253BAWW NOT WORKING
the ice maker wont cycle untill the temp of the ice is around 10 degrees so if the freezer is at 15 or 20 due to some other malfunction then you will see the maker full of ice but it wont harvest and make another batch. so you could have a sensor bad, control malfunction, refrigeration issue, compressor, defrost system malfunction(you mentioned ice build up)
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
