KitchenAid Architect Series KEBC278KSS Electric Double Oven displ
Hi, a few days ago I got a error dispay, I cleared and everything ok. Yesterday same thing except display is not coming on now, not the clock or the main display. Can you help me?
Hi!!
Call the KitchenAid Customer eXperience Center toll free:
1-800-422-1230.
Consultants provide assistance with:
• Features and specifications on our full line of appliances.
• Installation information.
• Use and maintenance procedures.
• Accessory and repair parts sales
Good Day! Don't forget to rate this post!!
hello there: the dreaded F2-EO code appears when the keypad has shorted out and needs to be replaced this is also known as the electronic range controle tis costs about 180 dollars and if the controle board need to be replaced this is about 250 dollars so if you can i would have both of them tested out before you spend your money on somethng you really dont need if you have the warranty you can use it to have it tested ok Best regards Michael
Thanks for using FixYa. Error F2-E0 on your kitchen aid means that the keypad is shorted and to resolve this issue you’ll have to replace the electronic range control/clock (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Hi, If your electric oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself... Check out this tip that I wrote about the Oven not heating problem..
Hello- the hinges are held in place by 4 screws on each side. Most doors have a point when closing where they will stop on their own. This is usually the point where you can lift up on the door to remove without pulling the screws out of the hinges. Hope this helps. Please acknowledge this post if the info was useful. Have more if needed.- Thanks- Ed
