Heating & Cooling Logo
Posted on Mar 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Furnace runs OK, but blower runs again a few seconds later
Happens more when cold, as in the morning or real cold outside temps. Furnace will run & heat normally, but after it shuts down, the blower will start up a few seconds later and run for only a few seconds. Usually once, sometimes twice in quick succession. Furnace is Carrier forced air, about 18 years old. Technician states ''that is what old furnaces do'', cleaned it, checked plenum for cracks, all OK.
Anonymous
Level 3:
  • Master 3,361 Answers
  • Posted on Mar 11, 2009
Anonymous
Master
Level 3:
Answers
3361
Questions
Helped
1029760
Points
10654
Could be a defective thermostat in the plenum.
When a gas furnace shuts down the fan(blower) will run until the plenum cools to the safe range. Usually 1 and 1/2 minutes.
Intermittent operation is a defective thermostat or relay.
Car loses power for short time after normal running and cooling down for ten minutes
sounds to be symptomatic of a CTS (coolant temperature sensor). there are two, one is for the interior temp gauge, the other is for the ECU/PCM while both are basicalty the same part, often even the same P/N, they both do extremely different things.
Ruud achiever 90 plus gas furnace flame goes out after few seconds
This could be water in the hoses that connect to the pressure switch , they should just pull off and blow then out also blow out the pressure switch , this sound like a moisture problem with all the bad weather you h, check air filter is not blocked .
I have a downdraft Goodman furnace. On only some occasions the blower will start, then after a few seconds I will see the igniter light up, but then I do not get the rush of gas and lighting of the...
It sounds like you got a tough one there.When you say the blower starts up and then the igniter comes on are you refering to induced draft motor or main blower. The proper sequence is for the thermostat to call for heat at which point the induced draft motor should come on and run for 30-45 seconds,then the igniter should heat up for a few seconds then gas valve should open and main burner should light. After limit switch reaches set point for fan on ,blower should come on till after heat has reached thermostat setting then burner should go out, and blower run until fan off setting is reached on limit switch. If your furnace is not following this sequence and then not always doing the same thing in the same order,I would recommend that you change out board again. I have had several problems similar to this with Goodman units and all but one time installing new board solved it. That time I did everything I knew to do and talked to factory service techs repeatedly and finally installed new furnace. As far as your question about insulation,. As long as it is fire proof I can't see where it would hurt anything. Sorry I'm not more help. Good luck and thanks.
5helpful
2answers
Gas furnace is constantly blowing cold air
An indoor blower running when it is not supposed to usually indicates an overheat condition. I would guess that it has been cycling on and off for some time and finally caused the high limit to stick and not auto reset. if you tap it sometimes they reset. the real problem is that it has been overheating from lack of airflow, over sized unit, not enough return air, too many closed registers, dirty filter, dirty squirrel cage blower and or air conditioner a-coil. If you get it started again sit and watch the unit run the flames should come on and stay on for the entire heating cycle, not going on and off.
I wish I could help you more but it is difficult without seeing the problem myself. Good luck! this should get you started!
1994 Carrier 58 PAV
sounds like the relay for the unit may be bad, usually if a blower motor goes it stops or has a very loud humm and only goes slow
1helpful
My 1999 pontiac sunfire won't start sometimes
so you changed the air temp sensor because ginko wrote the same thing in solution 8 how about coolant temp sensor
Furnace blower blows cold air
It is possible that you did not set the new blower on the proper speed. Black wire is high. Blue is medium. Red is low. If the fan is operating to slow it can run to hot and trip the high limit control. Make sure the filters are clean. When the old motor went bad, the problem might not have been discovered rite away your high limit control might need to be changed.
Also anytime you work on a furnace you can kick up some dust. Always clean the flame sensor.
Good Luck
HVAC Teacher
2answers
Heat Pump Stops Working only in the Early Morning
When the unit does what you say does the fan motor outside stop also , if it does that means it is in defrost mode and should kick back over to normal after the system heats up the coil enough
Goodman PHJK048 Heat Pump Package
ok...where to start.lol ....the thermostat is just a switch.It will tell the unit to run or not run.if you measure the temp with the heatpump running,the air is warmer than 68 but it feels cool to you because your body is 98.6.The unit will run more often and for longer periods when the temperature drops outside for a few reasons.First,your house has more of a load to heat,meaning you have more heat loss because of the difference in temperatures outside and inside.Second,your heat pump pulls heat from the outside air.The colder the air outside,the less btu's for it to pull.If you have anymore questions [email protected] Hope this helps,Dave
Top Carrier Heating & Cooling Experts
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
