Everything else works fine.cable box works through other inputs, but sure would like to get the HDMI to work.
Have you retried booting the hdmi cable by turning all products off remove hdmi cable then turn products on then re insert hdmi cable
If you are using multiple monitors on your computer and you get an issue with your HDMI port, it might be happening because you're using the wrong display setting. So it's a good idea to check this setting on your computer and make sure you use the right settings to display your screen.
Check hdmi cable first could have broken down
remove hdmi cable turn products off turn back on insert hdmi cable
Not the cable,got a new one,but thanks. Probably on the card, but can't seem to find somewhere online that has parts. Manufacturer aged me considerably on hold and told me they only have a few left at $250+.
