My tv has a dark picture and we can't get it to ajust. we try to adjust with the menu button but it just makes it darker,it won't lighten up.
Looking on the back of ur tv near the cable input jack there might be an area where u can adjust the brightness on the flyback transformer. if there isn't you will have to remove the back of the tv and adjust it this way. PLEASE DO NOT TOUCH ANYTHING OTHER THAN THE BRIGHTNESS KNOB ON THE FLYBACK, CAUSE YOU MAY BE SHOCKED. so please be careful.
To adjust the default lighter/darker setting
1. On the LaserJet 3015, press MENU/ENTER.
2. Use the < or the > button to select Copy setup, and then press MENU/ENTER.
3. Use the < or the > button to select Def. Light/Dark, and then press MENU/ENTER.
4. Use the < or the > button to adjust the setting. Move the slider to the left to make all of the
copies lighter than the original, or move the slider to the right to make all of the copies
darker than the original.
5. Press MENU/ENTER to save the selection.
Page 48 of the User Guide has instructions for adjusting the light/dark setting during a copy job.
Also see the Troubleshooting section of the User Guide for other possible reasons for light/faded copies.
If your copies continue to come out too light, you may need to clean the insert a new toner cartridge or change brands of toner. I tried several "generic" toner cartridges and refills, but my prints and copies were always faded or streaky. After going back to genuine HP cartridges, I haven't had any print quality problems.
