MSI Saturn 945 - MT - no CPU - RAM 0 MB - no HDD - GMA 950 - Gigabit Ethernet - Monitor : none Server Logo
Anonymous Posted on Apr 18, 2013
Kia Sportage 2000 4x4, Loud grinding sound every time i accelerate: I am getting a load metal grinding-like sound everytime I accelerate. The sound seemed to be coming from the Rear Diff. so I changed the diff Oil, it was very dark in color, and replaced with new diff Oil, Same problem, Load grinding. This metal grinding sound is only heard when I accelerate (mash gas). it stops once I release my foot off the gas pedal or if I am coasting downhill... its quiet. Can you tell me what is cause this load sound and how to fix the problem? Thanks.
Dayton Computer
Level 3:
  • Master 1,640 Answers
  • Posted on Jan 29, 2014
Dayton Computer
Master
Level 3:
Answers
1640
Questions
0
Helped
818158
Points
6396
You are in the wrong catagorey.
2003 Kia Rio when started finally it had a loud noise and sounded like it wanted to cut out.
Not enough information but sounds like you may have spun a bearing. Which means you will be engine shopping to fix it.
2answers
I have a 97 kia sportage rear wheel drive. Everytime you accelerate there is this terrible screeching noise that is so loud someimes it stops whennit shifts, other time it just gets louder. It always...
Now you found the problem you need to get it fixed at a garage this is not something you can fit at home type of repair. Cheers, Malcolm Campbell.
1helpful
99 kia sportage sputtering under acceleration
Hi Missippirebe, I think you should replace the fuel filter and if the problem persists check fuel pump pressure. It should be at around 3.7 bar. Regards John
1helpful
1999 kia sportage chassis acceleration sensor failed. I need the location and what it looks like.
The chassis acceleration sensor is located on the left side below the motor. Not on the motor but on a little metal plate connected to the body. I paid $55 at KIA for the part. The part # is 0K2NC-18911. They say it's a universal part. It took me two days to convince them the part even exist. But I have it now. I hope this helps.
2000 Kia Sportage 4x4 4 high doesn't pop into gear
www.kylestubbins.com just check this site and u ll get the problem sorted
201 KIA RIO MAKING A CRANKING/KNOCKING SOUND UNDER CAR WHY?
drive shaft uj change transmission shaft or possibly both
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
