Where is and was is siphon
SOURCE: error code 30
i fixed the problem by tipping the machine over slightly, as suggested by other members, about a pint of water came out the bottom and it now seems to work perfectly.
SOURCE: Hi, I have an aeg 60870 dishwasher showing error
Sounds like the Anti-Flood system activated (polystireen float at base of machiene coupled to a micro switch) the purpose of this system is to put the drain pump on and stops any other function on the machiene. The anti lood system activates when any amount of water appears on the bottom (caused by leaky pipe / blokked pipes / spills etc.) . Dry the water and rectify the leak. This should solve the problem.
SOURCE: My AEG dishwasher - Favorit no. 60870 sensorlogic
I don't have the answer - but mine has been doing this too. There's now a metalic/electical smell that has me worried so I've resorted to a basin of water and fairy liquid! Did you solve your problem?
