Trying to connect anothe lcd monitor to my d5150 . on boot up the secondary comes on stating I have to unplug it and plug a monitor into the primary vga port. I unplug the secondary monitor and reboot the cpu and go thru the sign in. At this point plugging in the secondary monitor intor the factory second vga port yields nothing. The desktop doesn't recognise it there at all. Please assist
SOURCE: Monitor and Mouse not working
GGGA indicates that the power on self test completed successfully.
GGGG indicates that the had off from the BIOS to the Windows Operating system was completed.
If you are not getting any video, and have an expansion video card, reseat the card. If you still don't have video, remove the card, and connect to the motherboard integrated video port (May have a black plastic cover on it)
SOURCE: Dell Dimension E510 Powers Up, Then Crashes
It's the processor or power supply. I cant be sure of which without checking it.
Check the fan over the processor heat sink to make sure its working cause it could mean that the processor is overheating If the fan turns and then it cuts off this could meant that the processor is dead. or the bios is corrupted. Try flashing the bios, there is a battery on the main boad, remove it. unplug the system first... when the battery is out press and hold the power button for 10 seconds then release. put the battery back in and try to turn it on..
If that fails then try a new power supply or one from another system to to check if the power supply is fine. YOu can aslo bridge the green and any black wire from the power supply's mainboard connector to see if the power supply runs. If all this fails then you may need to replace your processor,, I';d also recommend changing the power supply as well.
SOURCE: blank screen after boot up
This issue may occur if one of the following conditions is true:
Cause 1
loadTOCNode(3, 'cause');
This issue may occur if you have a CD, a DVD or a floppy disk in your CD, DVD, or floppy drive when you start the computer.
Cause 2
This issue occurs if one or more of the following elements are corrupted and will not load during the boot sequence of the computer:
To resolve this issue, follow these steps.
Resolution for Cause 1
loadTOCNode(3, 'resolution');
To resolve this issue, remove the media in your CD, DVD, or floppy drive and then restart the computer.
Back to the top
Advanced troubleshooting
loadTOCNode(2, 'resolution');
This section is intended for advanced computer users. If you are not comfortable with advanced troubleshooting, you might want to ask someone for help or contact support. For information about how to do this, visit the following Microsoft Web site:
http://support.microsoft.com/contactus/ (http://support.microsoft.com/contactus/)
Resolution for Cause 2
To resolve this issue, you must have the Windows XP CD-ROM. If you do not have the Windows XP CD-ROM available, you have to call your computer manufacturer to troubleshoot the issue.
If you have the Windows XP CD-ROM, use one of the following methods.
Method 1: Troubleshoot the specific element that causes Windows not to load
loadTOCNode(4, 'resolution');
Note This option requires that you perform multiple steps to determine the exact element that causes the issue. This option may allow for you to keep customizations in Windows.
Method 2: Repair your Windows installation
Note Repairing your Windows installation may change the configuration of Windows. You may also have to follow this step if you complete all the troubleshooting in steps option 1 and the problem is not resolved.
For more information about how to create a Windows XP boot disk, click the following article number to view the article in the Microsoft Knowledge Base:
305595 (http://support.microsoft.com/kb/305595/ ) How to create a bootable floppy disk for an NTFS or FAT partition in Windows XP
315222 (http://support.microsoft.com/kb/315222/ ) A description of the Safe Mode Boot options in Windows XP If you can start the computer from the boot disk without receiving an error message, the damage is limited to the master boot record, the boot sector, or the NTLDR file. After Windows XP is running, immediately back up all data before you try to fix the boot sector.
Use Disk Management to view the partition information and to verify that the disk partition (or partitions) is correct. To use Disk Management, follow these steps:
If invalid partitions are present or you cannot start your computer by using a boot disk, consider reinstalling Windows XP on your computer and restoring your data and configuration information from a recent backup.
If you do not have a current backup copy of the data on the computer, contact a computer specialist to determine the best method of data recovery and configuration.
For more information about how to use the Recovery Console, click the following article number to view the article in the Microsoft Knowledge Base:
307654 (http://support.microsoft.com/kb/307654/ ) How to install and use the Recovery console in Windows XP Note For more information about an error message that you may receive when you use the FIXMBR command, click the following article number to view the article in the Microsoft Knowledge Base:
266745 (http://support.microsoft.com/kb/266745/ ) Error message when you run fixmbr command Warning If your computer is infected with a virus and you use the FIXMBR command, you may be unable to start the computer. Before you use this command, make sure that the computer is not infected with a virus.
Windows XP Setup repairs the installation files, Windows XP automatically restarts, and then the Setup program finishes the repair of your Windows XP installation.
Note You must have your 25-character product key to complete these steps.
SOURCE: Remote connection doesn't display secondary monitor
I dont think it is possible to view anything but the primary monitor. I have used VNC many times as well as Crossloop (vnc program) never been able to view beyond that screen
SOURCE: Dell Dimension E521 would freeze halfway thru loading the BIOS
sounds like you fixed it yourself !!
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
