SOURCE: Ricoh Aficio 2045 error code sc 502
sc 502 is the problem related to tray lift motor .open the backside of the machine ,almost downside u ll find one spring broken .replace tat the tray will start working.
SOURCE: ricoh 2045 sc 990 when i fix printer its appear
Did the donner copier have a finisher on it? The code means a miss comunication with the finisher. There is a HD that is used with a finisher. The meter count can not be changed that I know of......The reason it shows 000000 is that the battery was disconnected from the eprom.
SOURCE: Fax error code on Ricoh 2045
network errors, like the 15-03, that you are receiving, have to do with fax "forwarding". the errors are thrown because the proper destination, or setup of the destination, for the forwarded faxes, are incorrect.
personally, i have not seen any 15-whatever codes. all the codes that i have dealt with are 14-01, 14-09, and 14-33. please double check the code that you are getting, and check the settings on copier.
14-01 and 14-09 codes usually mean that the smtp server name is incorrect, or the administrator e-mail address has not been added to the setup of the machine. although, it is still possible to e-mail directly without the administrator address being programmed. fax forwarding canNOT work without it. hence, the codes.
14-33 code usually means that there is an issue with the folder destination that the machine is trying to send to.
SOURCE: dear sir i have problem in ricoh 2045 its give the sc 990
if changing drum...
The problem persists.
Try press the .(point) and # key Both simultaneously more of 10 sec. This reset the condition, the copier shut off and on automatically and print a error report.
Also the hard disk
can cause this problem... change.
SOURCE: Sc 990 ERROR PROBLEM ON
replace drum, drum cleaning blade,charge roller. this will sort Sc 990
GAVD I2C
communica-tion
error
690-001: Y
690-002: M
690-003: C
690-004: K
