There seems to be no feature to lock the motor shaft in place to keep from rotating so i may remove the pad to replace it.
SOURCE: craftsman air compressor bearing flywheel
Your local hardware store should have one. The model number will probably not help; you will need to measure the keyway width and height to buy key stock of those dimensions then cut off the length you need.
Hope this helps.
SOURCE: How do i remove the air pump assembly off my
It is in fact bolted directly to the motor. You should be able to do any repairs necessary without removing the pump from the motor. I am not sure of the set up of that motor. I'm not sure if undoing that plate will also remove that side of the motor. (Something you probably don't want to do.) If you see other screws or bolts under the plate I would assume that you are safe to remove the pump plate from the motor.
SOURCE: broken cog on compressor motor 919.166440
Below is a link where they have a variety of parts for smaller craftsman compressors.
I didn't see an exact match for your model however I think if you contact them they will probably be able to help you out. I'm sure that motor/pump model was used on several different models.
Hope it helps.
http://www.mastertoolrepair.com/craftsman-sears-parts-portable-compressors-c-271_535_537.html
