Three things to consider when choosing memory
  • 5,660 Answers
1) What is the Maximum TOTAL Amount, that the motherboard will support.
2) What is the Maximum Amount for EACH ram memory slot.
3) What type of Ram Memory is it?
A) What type is it?
Single-Data Rate SDRAM?
SDR Sdram which is erroneously just referred to as SDRAM.
Double-Data Rate SDRAM? DDR Sdram
Double-Data Rate 2 SDRAM? DDR2 Sdram
Double-Data Rate 3 SDRAM? DDR2 Sdram
(See? They are ALL ->
Synchronous Dynamic Random Access Memory)
Then you get down to the basics, that is really supposed to be known...........
B) What Frequency Rate does it operate at? ('Speed')
200MegaHertz? 266MHz? 333MHz? 400MHz? 533MHz? 667MHz?
800MHz? 1066MHz? 1333MHz?
C) What Voltage does it use?
JEDEC has set the standard for Ram Memory.
'High performance' ram memory may use higher voltage.
Example;
DDR Sdram
JEDEC has set the voltage standard for DDR Sdram at 2.5 Volts (DC)
That is what the factory has set as a default voltage, in BIOS Setup.
High performance ram memory? May be 2.6 volts, or 2.7 volts.
D) Ram Timings;
Shorter to explain this way,
http://computer.howstuffworks.com/ram.htm
http://www.hardwaresecrets.com/article/Understanding-RAM-Timings/26
http://en.wikipedia.org/wiki/SDRAM_latency
E) Whether or not ECC or Non-ECC is to be used,
http://en.wikipedia.org/wiki/ECC_memory
ECC ram memory is generally used in a Server computer.
The data (Information) is analyzed 2 to 3 times, before it goes through.
F) Buffered or Unbuffered ram memory:
http://en.wikipedia.org/wiki/Buffered_memory#Buffered_memory
G) Chip Configuration:
The black rectangle chips on the side/s of the ram memory module ('Stick'), are called DRAM chips.
They are arranged in an order, and connected via circuitry, to be accessed as the ram memory manufacturer has deemed.
This you shouldn't have to worry about.
In fact you can probably get away without knowing D) also.
What test is this for?
Post back in a Comment
Regards,
joecoolvette
Posted on Apr 19, 2013
6ya staff
SOURCE:
Tip
Why choose HP Pegatron M2N78-LA ASUS OEM Violet6-GL8E??
Things to be considered in choosing HP Pegatron M2N78-LA ASUS OEM Violet6-GL8E
1. Processor and Memory upgraded
3. I/O Ports and Network
5. Clearing BIOS password
For details you can visit web site www.hpparts.us
on Apr 02, 2014 | HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS...
I have nokia n72 and my problem is that when i insert memory card it shows(memorycard currepted) i have changed three(3) times card and every card have same result. so please have thjis problem any...
If its not the memory card that is giving you the problem, its the slot. The slot is likely damaged. But as I said earlier, why go for N72? It has a very low Talktime battery. About 3 hours. When buying a phone consider the Talktime of the battery. Choose one with around 10 hours or above.
Oct 04, 2011 | Nokia N72 Cellular Phone
CAN YOU TELL ME WHAT IS THE SPECIFICATIONS OF THE MEMORY? THE SPEED AND SIZE AND WHAT ARE THE THINGS TO CONSIDER?
In simple terms no. Things to consider:- TURN OFF CAPS LOCK!
Spec of the memory in what?
Speed and size of what?
How long is a piece of string?
Mar 15, 2011 | Computers & Internet
What are the main things we should consider,when we buying new desktop computer...?
You should consider the amount of RAM (how fast the computer runs) I would recommend a minimum of 2GB , then also the amount of HD space (the memory you can store things on like pictures videos and music) I would recommend a minimum of about 250GB or more if you have a lot of pictures and videos or like downloading a lot. You also need to consider the screen size , most screens are about 15-17 Inches but if it's a Apple iMac like mine you can get a lot bigger screens with a maximum of 27 inches which is HUGE! but those are usually EXTREMELY expensive and are usually used for video editing , games and designing. So i would recommend about a 17-19 inch screen depending on what you want to use it for. Then there is also what OS (Operating System) you want but before you can choose that you need to know if you want a Apple iMac or a Windows PC . Once you have chosen you can get an iMac with the latest OS Snow Leopard or if you choose Windows you should look for Windows 7 the latest from Windows. Also what sort of disk drive it has e.g. DVD re-writable or a light-scribe but those cost a lot. Then there's the processor i would recommend Intel . And lastly the amount of ports e.g. USB , Memory cards. Check how many USB ports there are those are the most commonly used ones.
Thanks and I hope this helps. ;)
Apr 16, 2010 | Intel Computers & Internet
I need a manual for a Berkley fs50 scale
Operating Instructions1
A. Powering-on the scale
1. Press and hold the POWER button for two seconds. Scale will perform a self-test by displaying four 8s for three seconds. When "0.00 kg" or "0 lb 0 oz" is displayed on the screen, scale is zeroed-out and ready for normal operation.
B. Normal Weighing
1. Hang fish on the attached hook. Weight is displayed in either kilograms or pounds and ounces.
C. Switching between unit weights
1. Press and hold the POWER and CHOOSE button simultaneously for three seconds. Unit will change from weighing pounds and ounces to kilograms and vice versa.
D. Taring Weights
1. Weigh a bag or container till its weight is steadily displayed on the screen.
2. Press the POWER button once. Scale will zero-out and show "0.00 kg" or "0 lb 0 oz" and is ready for weighing multiple fish together.
E. Holding a weight
1. With the weight displayed on the screen, press the CHOOSE button. This will hold the current weight and is indicated by displaying an H to the left of the screen. To unlock the hold, simply press the POWER button.
F. Storing weights into memory
1. With a weight in the hold mode and an H displayed to the left of the screen, enter the memory mode by pressing the CHOOSE button. While in the memory mode, pressing the CHOOSE button will allow you to navigate through ten stored memories. These are indicated on the left and numbered 0 through 9. There are also 4 letters that indicate other options. An A shows the average of all stored weights. An E displays the total and a C resets the memory.
2. To store a weight, simply hold down the CHOOSE button for three seconds. Weights will automatically store into one of the number registers. To see the numbers with their weights, simply scroll through the numbers by pressing the CHOOSE button as described above.
G. Resetting the memory
1. With the unit in the C mode, press and hold the CHOOSE button for six seconds and scale will reset memory and zero out. Press the POWER button and scale is ready to begin weighing again.
H. Powering-off manually
1. Press and hold the POWER button for 6 seconds.
Dec 09, 2009 | Berkley Twist Lock Rod Rack
How do you transfer internal memory to memory card
-Turn On camera
-Press menu button and look for setup menu
-Under setup menu Look for the word image storage then Press Ok button
-Under image storage choose Internal memory then press Ok Button
-Now if your setting is in internal Memory turn Off camera.
-Turn On camera again
-Press review Button to show pictures in Internal Memory
-Press Menu button then Choose Copy.
-Now under copy wil provide three option copy ALL/PICTURE/Exit
-If you wnat to transffer all the pictures to you memory card choose all if selected picture just choose picture.
-Now your picture in internal memory is in your memory card
_Note; You need to set your iamage storage to Auto again for you to able to access or used the Memory card
Nov 08, 2009 | Kodak EasyShare C653 Digital Camera
Cant get past error even tryed to repair windows or how can i install reinstall
Try booting into safe mode by pressing F8 when boot up starts. Choose safe mode. When it's booted up, right click on "my Computer" and choose properties. Click on advanced and choose the advanced tab. Go to performance and change the settings of Virtual Memory to what Windows Recommends.Restart.
May 29, 2009 | Gateway Essential 400 PC Desktop
Pillow support
Memory foam neck pillows come in many varying densities, sizes and shapes. Usually, when you seek out a chart for memory foam pillows, they give you suggestions based on your height only. While that is a good start, you need to also consider the following: Do you sleep on your side, back, stomach or a combination of all three? Do you prefer a small, medium or large pillow now? What kind of pillow are you used to sleeping on? Is it firm, medium or soft? Do you suffer from neck pain? Knowing the answer to these questions will help you in selecting the right memory foam pillow, or may suggest that you would prefer a different pillow altogether. For example, if you sleep on your stomach, a neck pillow might not work at all. You might want to check out a memory foam pillow that's shaped like the standard pillows we all grew up using.
Aug 27, 2008 | Brookstone Theraspa Turbo Massager
Computers & Internet Logo
388 people viewed this question
Ekse
Marvin
Marvin
