Ive had my kmix for just over a year 12months 3 weeks!!! and it is making a grinding noise, it works fine but under load this noise really kicks in and i turn it down or off as I thing the things going to blow. I rang the Kenwood people and the guy listed to it over the phone and said it sounded like it needed re-lubricating. Kenwood repair people said they have not done this and sounds like a drive shaft, gear, problem of something is out of alighnment, all sounds like its going to cost loads.................help.
SOURCE: Blakeslee (Kenwood) A717 mixer speed control
I had the same problem. Had to strip the machine down to get to the motor. On the top is a moving plate with various capacitors etc mounted. On the front side there was a Capacitor (At least I think it was) with the wire broken.
I resoldered it and the machine now works fine.
I hope this helps
SOURCE: Hi,we have an old kenwood chefette hand mixer with worn parts.
does anyone know how I could get the whisk beaters for a Kenwood A375? Was given mixer but no whisks!!
SOURCE: can't remove beater kmix from machine. it's stuck!kenwood
Here's how to fix the stuck implement problem:
The implements
each have adjustable heights. to adjust the height you need to loosen
the bolt at the top with a 14mm spanner. If the bolt was loose when it
was being used then it can get too short and not leave enough clearance
between the bolt and the machine in order to push up and turn to release
the implement. If this happens take the open ended spanner, grasp the
implement and rotate the spanner clockwise (when looking up at the
machine from below. Once the nut is loose rotate the implement until
there is enough clearance to remove it normally.
