Question about Actiontec GT704WG Wireless Router (gs583ad3-01)
Open nat on ps3 for actiontec GT784WNV
Trying to get open nat on my ps3 ive tried port forwarding but the best it goes to is moderate and I have to reset my router everytime I want it to be moderate instead of strict anyone know the solution?
5 Suggested Answers
Anonymous
SOURCE:
Anonymous
  • 51 Answers
SOURCE: trying to open gamer port on my actiontec router to play xbox360
It looks like what you need setup is port forwarding. You can visit this link for details specific to the router manufacturer.
http://www.portforward.com/english/routers/port_forwarding/routerindex.htm
Hope this helps :)
Kindly leave a good feedback. Thanks..
Posted on Nov 27, 2007
Anonymous
SOURCE: GT704-WG with Verizon firmware
For those with the Verizon version of the firmware wanting to setup a Slingbox... You can go to the Security tab and then go to the Games tab and setup the 5001 port from there. It works.
Posted on Jan 29, 2008
govinda123
Prashant M
  • 2277 Answers
SOURCE: ok my nat type is strict and i am trying to change to open
You want the NAT open for X-box ?
For X-box you will need to open some ports on the router.
Also you will need to reduce down the MTU on the router to 1365.
That will work.
for this you will need to open the router set up.
Click here for more info about x-box and router settings
Posted on Dec 10, 2009
Tom Marvolo
Rakesh Warrier
  • 708 Answers
SOURCE: I have an actiontec router
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is enabled
Posted on Aug 20, 2010
Default password for actiontec gt784wnv
Hi Brenda.
this is all i could find.
To change your Actiontec GT784WNV password: Open your Web browser and enter http://192.168.1.1 in the Address field. Enter your user name and password and click Continue. Your default user name is admin if you didn't change it when you configured your network.
Actiontec GT784WNV: Changing your password ' Highspeed Internet ...
https://www.verizon.com/support/residential/internet/highspeed/.../atlas6609.htm
or go to this link.
Default password for actiontec gt784wnv Google Search
Nov 03, 2017 | Actiontec Computers & Internet
I am trying to games on PS3 and cannot connect with friends. I believe this is because I have NAT Type 3 (closed) and I would like to change it to NAT Type 2 (moderate) but I do not know how.
Hi ..
The PS3 has 3 different NAT types. They are shown below.
Type 1: The PS3 is connected to the Internet without a firewall or router. No NAT issues.Type 2: The PS3 is connected to the Internet through a router which is configured correctly. No NAT issues.Type 3: The PS3 is connected to the Internet through a router that needs configuring.Ideally, you want to have a Type 2 NAT. However, a Type 1 NAT does not affect your game play.
First of all you will have to Disable the firewall in the Router / Modem
If you are using a Router ..
Then
Make sure that UPnP(Universal Plug n Play) is enabled
Enable the IP Address of the PS3 in DMZ
Or Forward the ports
Below are the TCP and UDP ports that need to be forwarded:
TCP: 80, 443, 5223
UDP: 5223, 3478, 3479, 3658
For more details on port forwarding , log on to http://portforward.com/english/routers/port_forwarding/routerindex.htm
Hope it helps
Regards
Tom
Aug 18, 2011 | Computers & Internet
I have an actiontec modem connected to my ps3. When I play call of duty my Nat is moderate. How can I get my Nat set as open?
you should try to get your nat type to say not availible and look on youtube for help
type in help with getting nat type to not availible on ps3
Jan 18, 2011 | Video Game Consoles & Games
Hi there! i have a zyxel ph660-f1z and since it doesnt suport dmz i get nat type moderate on my ps3 so it gives a lot of trouble.... i have tried port fordwarding,upnp,default server but nothing seems to...
Sometimes not just the dmz or port configurations cause your nat settings to be other than open, you may not have good internet connection, the better it is the more you will open. Most routers are open by default, and those others need to be forwarded(like you wrote) with the upnp open and specific ports for xbox/ps3 servers opened. You seem to know a little already, maybe time to get a new router?,I recently upgraded myself due to problems with configuration.
Dec 15, 2010 | Zyxel P660HW-D1 Router
I have a PK5000Z from Qwest, and an XBOX360, I had an issue previously with a PK5000 made by Actiontec, with NAT issues, set to moderate, it doesnt let me hear all players in a xbox live party chat, or in...
try turnig off all restrictions related. like , S.P.I. (statefull packet inspection) and try setting firewall setting for the address of the Xbox to "DMZ" . check setting of M.T.U. in router, adjust it to 1580
Good luck.
Sep 27, 2010 | Computers & Internet
Once i open my router how do i actually open the ports for xbox tcp80,udp88,exctra im using a action tec gt704wg wireless router
http://www.actiontec.com/support/product_details.php?pid=40&typ=doc
Your manual above it also shows you how to open ports in there.
Also if you go to http://portforward.com/, they will show you how to do it too. Go to the link below.
http://www.portforward.com/networking/staticip-xbox360.htm
Actiontec Gateways and Routers are compatible with the Xbox. However, it may be necessary to forward the ports used by the Xbox, in the Actiontec Gateway or Router. Without Port Forwarding, the Xbox Connection Test may report a "NAT" rating of "STRICT" or "MODERATE", rather than "OPEN".
It is also explained below...
Aug 21, 2010 | Actiontec GT704WG Wireless Router...
I have an actiontec router and cant set my nat type to open. If i turn off nat i cant get on xbox live. It says in the actiontec website for my router that i have to do something with port forwarding to...
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
Aug 09, 2010 | Actiontec (GT701WG) Wireless Router
I have a Westell Versalink 327W with a strict nat and I want to open it up for Xbox Live. I have tried port forwarding but that only bumps it down to moderate not open. What should I do?
PS3 and Xbox ( NON BELKIN)
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is Enabled
May 19, 2010 | Westell Wirespeed VersaLink...
Ps3 is on nat setting 3 strict
You need to forward a port for gaming. Call Sony and ask them what port should you open. Or go to www.portforward.com if you wanna know what port would you like to open
May 15, 2008 | Computers & Internet
Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
160 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Ekse
ThaMp3Doctor
ThaMp3Doctor
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
