Hi, I have a Craftsman 919.167311 compressor. It will run for about 5 seconds before it trips the breaker. it has no pressure in the tank. I have disconected the pump to make sure that ther eis nothin
AO Smith motor K56B04B23, 30gal, 6hp, pump- D27348, 2002 year model
check the amps requirements for the compressor, it should be at least 20 amp breaker without much else on it running at the same time.See what else goes off when breaker trips
Your tank check valve is stuck/broke. It's on the tank end of the line from the pump to the tank. It is supposed to close when the pump stops to keep air in the tank and let the system bleed pressure out of the pump so the motor can start when there is pressure in the tank. The part you need is CAC-437-2 and is available through searspartsdirect.com.
Try it on another circuit to check the breaker. Tighten the screws on the breaker which hold the wires. This will determine if it is a problem with the compressor.
Sounds like the unloader valve is not working properly. The unloader typically is at the end of a tube going to the pressure switch. The unloader is tripped when the pressure switch cuts off. The purpose of the unloader is to bleed the pressure from the cylinder when the compressor cuts off so the next time the compressor cuts on it will be starting in an unloaded condition.
when the compressor cuts off you should hear a discharge of air for about 3 to 5 seconds if the switch is working properly. The unloader can be adjusted if necessary by loosening the jam nuts and adjusting the unloader towards the lever on the pressure switch.
First, the simple answer - check the AMP draw on the compressor. It should be on the motor or compressor nameplate/tag. Even a small compressor can use alot of power, and blow the breaker if there are other things on a circuit.
Sounds like one of the following three possibilities:
Too small of service to the unit... You need 20 amp and #12 wiring.
Too long extension cord with too much voltage drop.
The "unloader" is defective. This is a little valve that MAY be a part of the pressure switch that bleeds cylinder head pressure at shutdown to make starting easier. At shutdown you can usually hear it "exhale".
Air compressors tend to draw more power as they age, however, will not trip breaker unless some malfunction. Here are some simple tests. Unplug compressor and turn the pump by hand, you may have to remove a cover to do this. It should turn freely; any resistance could be failing bearing (would make noise) unloader/check valve leaking allowing back pressure to pump, or failed start capacitor/start winding. Easy test for checkvalve. With pressure in tank loosen discharge hose at tank and check for air leak. Check valve should hold pressure in tank. Replace as needed. Failed capacitor/s will cause high amp draw. Remove from circuit and test. UF reading should be within 95% of printed rating. Finally, most air compressor motors have two windings, start and run. Power to windings is controlled by flyball switch inside rear of motor. This switch has contacts that can stick in start position and cause high amp draw. Examine windings for signs of overheating. Copper windings generally have color of new penny. Very dark brown windings bad news. Gook luck
Does this trip on pressure or is it a breaker tripping? If you took off the intake then there is no pressure build up, thus it wouldn't trip the pressure switch. But would at the same time add a load to the motor. First check and make sure motor is wired properly, then check that pressure switch is wired properly and is adjusted to the right pressure. I don't believe that the intake tube would be clogged, it's a straight hole into the tank. But could be a possibility.
