You can unlock your Blackberry 9300 Curve 3G from Network lock easily by using unlock code.To get this code at low cost visit the site Prounlocking.com here you need to specify the IMEI number of your phone,Country,Network provider to which it is locked.Then they deliver the unlock code to you through E-mail.Using that code you can unlock your phone easily.After unlocking from Network lock,you can use any GSM network SIM card on your mobile.
Use unlock code to unlock your Blackberry 9300 Curve 3G. Get the code from the site Classicunlocking.com ,here you can unlock your mobile yourself using unlocking instructions.
SOURCE: my keyboard backlight for blackberry
I found out on here how to fix it. You take the battery out, while the phone is turned on, leave it for 30 secs then put it back in. So far it seems to be working.
SOURCE: I cannot see incoming call
it include two solutions first take a anothe network sim card then check still the same problem occur if now the caller id is visible ask your service provider that whether they acivate the caller id service for your mobile number then check in your mobile that you disable the id . This is on the option like show my caller id (see is this this enabled or disabled if you disable this enable it) i suggest you better you try the mobile restore option
SOURCE: my blackberry curve 9300 is
Cursor or Trackball malfunction problem can be fix by cleaning the interface or trackball replacement.
First step is by following this simple guide.
* Remove the back cover and the battery,you will see a metal shield cover and a screw,unscrew it using a T6 precision screw driver or any tool that can release that screw,lift up the metal cover and you'll see a flex connector,gently release that connector upward using any flat thin object like twizzer,now clean the both pin connector from the board or trackball connector using any rust solution and a cotton,be sure it is dry before putting it back,now assembly that portion and try if it is working.
Second or Last step.
* Otherwise you need to replace a trackball so you can use it properly,or go to a mobile service shop for parts replacement.
SOURCE: I forgot my password for
You have to reset your mobile..This can be done by codes..I found the security unlocking service at Prounlocking.com .Through this you can reset your mobile easily..
SOURCE: RIM BlackBerry Curve 3G 9300 mep code 0
There is one option left to unlock blackberry curve 3G 9300 if your mep counter attempt to 0, in this case blackberry unlock code will not affected anymore. You must doing cable unlocking process, this method will force your blackberry unlocked and you can do that at mobile repair shop.
