Either the charger is not working, the battery will no longer take a full charge, or the detection of a full charge is not working. If the trimmer works as long as it used to after charging 24 hours I would not worry about it. If not, then try to find another charger that has the same volt AND amperage rating and the same end (may be difficult) and see if the red light goes off. If still no good then you need a new battery. MAY be possible to have someone who sells the unit test the battery or you can test the charger to see if it is supplying the correct output. Checking with the dealer or manufacturer is always an option to consider.
sounds like the battery is bad and not taking charge.replace battery attemp again if not then check for fuel, spark and compression.then c wat happens or wats not working any motor no matter how small or big has to hv those three things to run. hope this helps.
LED Light 1 (L1) - is by the earphone socket LED Light 2 (L2) - is by the USB connector
Charging: Please switch on the player before charging. (Push the on/off switch to 'on' )
When charging the battery for the first time it is recommended that the player is charged about 8 hours. Connect the player to an active USB port using the supplied cable. The computer must remain on during the charging process. Recharging: Recharge the player will take about 3 to 4 hours. When it's charging, L2 will turn on in red, when it's fully charged, L2 will turn to green light. When playing music, L1 will shine.
The yellow light means that there still is an amount of charge on the battery, meaning that it isn't fully discharged. The red light means that it is partly discharged and you can charge it up.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
I don't know how to solve your problem but, the three lights mean this:
Red LED light indicates the battery is being charged
Green LED light indicates that the battery is fully charged
Amber LED light incidates that the battery power level is low - the battery needs recharge.
Do not recharge you battery over 24 hours.
Not sure if this will help... however an altmeter will allow you to test along your electrics for any faults. You can check at the lights for example and throught the system.
