Sounds like something is wrong with your tilt and trim motor. You can find some replacements below.
http://www.iboats.com/Evinrude-Power-Tilt-and-Trim-Motors/dm/view_id.269667
SOURCE: cant find how to tilt evinrude outboard
have you got hydraulic trim/tilt? if so control button /switch will be on or near throttle handle-if not you will have to manually lift and insert pin at bottom of mount on transom
SOURCE: my 1978 140 evinrude electric trim tilt motor
First make sure you are not in transit mode. Some outboards have a lever which keeps the motor tilted for trailering. You should have a fuse for the tilt motor, check that. If the pump is turning and it sounds like it is whining you are pushing air and either lost your hydraulic fluid or have an air bubble in the system. Check your fluid reservoir.
