Question about Lexmark X4650 InkJet Printer
Clear plastic piece fell off, don't know where it goes now!
The plastic strip fell off from behind the carrier in my x4650, and I took the printer apart to fix it. Now another clear plastic piece fell off the right side of the printer (electronic side) from inside the grey end cover and I can't figure out where it goes nor can I find a simple parts manual. The piece is S shaped with a white beveled tip at one end and a notched tab at the other.
5 Suggested Answers
6ya staff
SOURCE:
Ajkill
Anand Kumar
  • 2035 Answers
SOURCE: Lexmark P4350 problem, anyone have a service manual?
Its the encoder strip if come out from one side ur printer is defective it cannot be replaced back..if it is out its position please
Use this link to trouble shoot:::
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:479:0:0&framed=&docid=ENUS22722&relevance=0
Posted on Mar 16, 2008
Anonymous
SOURCE: Carrier Jam
THis solution I copied from another post. It worked for me as well
First you need to open the printer. Unplug from power. Then lift the scanning device, you can partially remove it when pushing the "hooks" close to where the lid is connected (careful with the cable connections). Then remove three screws in the cover of the bottom part and with some fiddling around you can remove the cover. Again be careful with the cable connections. Of course don't do it if you are worried about warranty or breaking the printer.
The plastic strip has slits at each side to attach to the inside back of printer, on the left side is a down ward facing arrow, the plastic strip feeds through the back middle of the cartridge carrier and then the slits are to be inserted to the metal tab like pieces on the back sides inside the printer on the right side (facing printer) it will look like a small rectangular hole with a longer metal tab like piece sticking out & on the left is a smaller squared like hole with a flat smaller metal like tab which will line up if the plastic strip is feed through the back of the cartridge carrier properly. This should allow the cartridge carrier to glide properly & work as it should, with no more banging.
Success
Posted on Dec 18, 2008
nalin_elliot
Nalin DSouza
  • 224 Answers
SOURCE: Clear carrier jam is error message
Not that difficult check if behind the carriage(part holding cartridges) has broken off.Its a small plastic latch about 3 inches in length.
If not then try moving the carriage manually with your hand and see if it moves if it doesn't press and hold the power button and while holding the buttons unplug and re-plug the power cable to the printer .Clean the carriage rod with alcohol on a cotton swab/lint free cloth and then see if the problem surfaces if it does then its time to get a new printer
Posted on May 30, 2009
printmastert
Lexmark
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: I have a lexmark x4650
    The "plastic strip" could be the encoder strip (responsible for the movement of the cartridge carrier on the assembly). This article will give you an idea on how to re-seat the encoder strip on your printer: Printer Cartridge Stalls or Is Blocked.
    If you still need assistance, please contact Lexmark Technical Support Center.
    Posted on Aug 17, 2011
    Carrier Jam, there's nothing in it, I put new cartridge in still saids carrier jam, other then that this thin strip came out
    The thin strip could be the encoder strip (transparent strip) which is responsible for the proper movement of the cartridge carrier along the carrier assembly. Please contact Lexmark Technical Support Center for additional assistance.
    Sep 21, 2011 | Lexmark X4650 InkJet Printer
    I have a lexmark x4650 printer and my son pulled a plastic strip from some where. Now my printer tells me that the cartrige is jam. When I opened it there was a small spring that I have no idea where it...
    Aug 16, 2011 | Lexmark X2350 All-In-One InkJet Printer
    It shows "remove any obstruction
    Open the printer cover and access the cartridge area. Remove both cartridges. While the cover is open, check for any obstructions in the cartridge carrier's path. Check for any loose transparent strip (encoder strip). If cartridge area clear from these, Close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, open the printer cover and reinsert the cartridges. Close the cover and try to print again.
    May 27, 2011 | Lexmark X4650 InkJet Printer
    I have a x4650 that says carrier jam and theres nothing in it. there is this long thin clear piece that i think came out it, how do i get it back in.
    The long thin clear piece is most probably the encoder strip. The encoder strip has something to do with the communication in the printer to determine the location of the ink cartridge carrier on the carrier shaft. But, unfortunately, that can be hard to hook back in since it's connected way inside the printer. I strongly suggest you contact Lexmark Technical Support for further assistance.
    May 19, 2010 | Lexmark X4650 InkJet Printer
    When powered on the ink cartrige goes back and forth across the carrier very fast and makes a loud noise as it hits at both ends. The power botton is flashing two (2) times at a time.
    Home position sensor error,the mylar strip in back of cartridge carrier has been removed or has contaminants on it.
    You should be able to see a clear piece of mylar running behind the carts from end to end.
    If not there check for a 11 inch by 5/16 inch piece and reinstall or clean piece already there.
    Aug 14, 2009 | Dell Inkjet 720 Printer
    The runner in the printer
    The encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
    The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
    The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and try printing the self test. If it slams to the left again, the strip is not yet set correctly.
    If you cannot repair the strip, please let us know so that we can assist you further.
    Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer.
    May 08, 2009 | Lexmark Z845 InkJet Printer
    Carrier Jam
    This is what my printer did when it kicked of the 14" plastic strip inside the printer(see posts referring to strip). Look inside for a loose, quarter inch wide and 14" long plastic strip with slots on the end. Let me know if you solve this.
    Dec 15, 2008 | Dell 926 All-In-One InkJet Printer
    Carrier Jam
    Success
    Jul 16, 2008 | Lexmark P4350 All-In-One InkJet Printer
    Carrier jam
    Is it a clear plastric strip with little black lines through it?
    If so that is your encoder strip, it is how the printer knows where the head is. If it's broken it needs to be replaced. If it just came out of it's holder you may be able to put it back into place. Sounds like it snapped, not good.
    Jan 14, 2008 | Lexmark P6250 All-In-One InkJet Photo...
    Piece has fallen out of printer
    Yea I had the exact same problem with my Lexmark X1185
    Was very lucky I didnt throw out the clear strip thingie before learning what it was :)
    Anyways the strip itself passes through a shader sensor located on the rear or the cartridge carrier.( see pic 1 ) .
    The second picture shows everything else in close detail Including which side of strip goes where.
    Pay attention to the spring (circled in yellow) because i believe it is the cause of the whole problem...The spring end was pulled straight or has too little tension .
    Aug 12, 2007 | Lexmark P4350 All-In-One InkJet Printer
    Lexmark X4650 InkJet Printer Logo
    66 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Clive
    Clive
    Ekse
    Thomas F. Schneider
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
