Video Game Consoles & Games Logo
myth Posted on Apr 15, 2013
Prism3d crash on windows 7and 8
Crash details ******** : log created on : Saturday April 13 2013 @ 22:25:45 22:25:45 : [sys] running on x86 / Windows XP (version 5.1) / Service Pack 3 22:25:45 : [sys] DirectX version : 4.09.00.0904 22:25:45 : [cpu] GenuineIntel [ Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz] at ~2495MHz. 22:25:45 : [cpu] Features utilized: fpu cmov mmx sse sse2. 22:25:45 : [mm] physical memory detected (1048575K/1048575K) 22:25:45 : [mm] virtual memory detected (2097024K/2023632K) 22:25:45 : [mm] Trying to allocate memory pool (153600K) 22:25:45 : [zipfs] base.scs successfully mounted [crc_0xb39eb8f] 22:25:45 : [zipfs] patch.scs successfully mounted [crc_0x48ebc600] 22:25:45 : [game] 18 WoS Haulin init ver.1.06 (rev. 19698) 22:25:45 : Home directory: 'C:/Users/RiverWind/Documents/18 WoS Haulin' 22:25:45 : exec /home/config.cfg 22:25:45 : [cor] executing /home/config.cfg 22:25:45 : uset g_minicon "0" 22:25:45 : uset g_console "0" 22:25:45 : uset g_trackir "1" 22:25:45 : uset g_developer "0" 22:25:45 : uset g_save_idx "1" 22:25:45 : uset g_mouse_control "0" 22:25:45 : uset g_steering_func_param "0.0" 22:25:45 : uset g_joy_axis_brake_dz "0.0" 22:25:45 : uset g_joy_axis_brake "7" 22:25:45 : uset g_joy_ff_gain "1.0"
1 Related Answer
Shhoo
Shh
  • 52 Answers
  • Posted on Nov 10, 2009
SOURCE: Valuesoft / arush : Hunting Unlimited 4, I get ''error prism3d".
Valuesoft homepage says:
This error message is stating that you need to update your video card drivers.
How do I stop Acid Pro 7 from crashing on Windows 8.1?
The only "problem" is Acid finding SampleTank 2 when I try to open projects created on xp / win7. Because it's 32bit it installed in (x86). The file path seems to be the issue (since "x86" is not in the file path on xp/7) but other IK apps open fine with xp/7 files and SampleTank 2 opens fine in new projects. if file path consistency is to be maintained a 64bit version is needed...?
RE Tips for installing Acid Pro 7 in Windows 8 1 Sony ACID Product Family...
See this webpage as Sony says it is Windows 8.1 compatible
http://www.sonycreativesoftware.com/acidpro/techspec
contact Sony support for this product.
Technical Support
Mtp function problem
Samsung MTP function Problem Solution It really worked for me.
1.)first copy umdf.exe from "wmp11-windowsxp-x86-enu.exe" to your Desktop, two methods:
a)unpack wmp11-windowsxp-x86-enu.exe(ex:with TotalCommander->Alt+F9) and copy umdf.exe to your Desktop
b)run the wmp11-windowsxp-x86-enu.exe(if you run it will extract the %TEMP% folder)
Click Start -> Run -> %temp% [ENTER]
Press F3 and search for "umdf.exe"
Copy this file to your Desktop
Cancel the WMP11 Setup
2.)Rename the folowing files, just copy&paste into your Command Prompt:
rename C:\WINDOWS\system32\drivers\wudfrd.sys test_wudfrd.sys
rename C:\WINDOWS\system32\drivers\wudfpf.sys test_wudfpf.sys
rename C:\WINDOWS\system32\wudfhost.exe test_wudfhost.exe
rename C:\WINDOWS\system32\wudfsvc.dll test_wudfsvc.dll
rename C:\WINDOWS\system32\wudfx.dll test_wudfx.dll
rename C:\WINDOWS\system32\wudfplatform.dll test_wudfplatform.dll
rename C:\WINDOWS\system32\wudfcoinstaller.dll test_wudfcoinstaller.dll [ENTER]
3.) Now run the umdf.exe and re-install it. After it's finished connect your phone and your MTP problem is solved.
Oct 24, 2010 • Cell Phones
35helpful
5answers
How to play 18 wheels of steel haulin in windows 7
Right click on the .exe file, go to the compatibility tab and select an inferior operating system. Apply, Ok and it should work properly
2helpful
2answers
1helpful
Memory file dump error, pc freezes
This is the issue with your RAM chip or Operating System .Pls replace the RAM chip with goods one and on the system .If still problem not resolved pls re-install the Operating System again.
Computer crashes event 52
Hi Sharon21,
As Microsoft says this problem occurs when the Patch UI Monitor component tries to call the client user interface (UI) when no user is logged on.
You can download hotfix available on the Microsoft site.
Run the SMS2003-RTM-KB831648-X86-ENU.exe update file, and then follow the instructions in the wizard.
Regards
ELLIN
Top ValuSoft Video Game Consoles & Games Experts
Aron
john h
Are you a ValuSoft Video Game Console and Game Expert? Answer questions, earn points and help others
