The only "problem" is Acid finding SampleTank 2 when I try to open projects created on xp / win7. Because it's 32bit it installed in (x86). The file path seems to be the issue (since "x86" is not in the file path on xp/7) but other IK apps open fine with xp/7 files and SampleTank 2 opens fine in new projects. if file path consistency is to be maintained a 64bit version is needed...?
Samsung MTP function Problem Solution It really worked for me.
1.)first copy umdf.exe from "wmp11-windowsxp-x86-enu.exe" to your Desktop, two methods:
a)unpack wmp11-windowsxp-x86-enu.exe(ex:with TotalCommander->Alt+F9) and copy umdf.exe to your Desktop
b)run the wmp11-windowsxp-x86-enu.exe(if you run it will extract the %TEMP% folder) Click Start -> Run -> %temp% [ENTER] Press F3 and search for "umdf.exe" Copy this file to your Desktop Cancel the WMP11 Setup
2.)Rename the folowing files, just copy&paste into your Command Prompt:
This is the issue with your RAM chip or Operating System .Pls replace the RAM chip with goods one and on the system .If still problem not resolved pls re-install the Operating System again.
