A couple of the phones in the office won't turn on. They just beep and and flash lights every couple of seconds. All cables are plugged in the correct places. Any suggestions? Thanks
SOURCE: Two questions: We have Panasonic KX-T7630
If you mean the 10 number stored in 00-09, from the phone, pick up the handset (or press intercom) and dial *30 00-09 9 plus the number and # You'll hear a confirming tone. That stores the number. To dial, you press Autodial *00-09 and it dials the number.
What's under the buttons? Press PROG and the button and it will show what's there. Probably a digital station that isn't there. Press 2 and STORE and you'll clear the button.
Carl
I found this post via genvibe.com, it worked for me on my 07 Vibe:
This will turn off the 1 minute beep if the car is running and either the passenger or the driver takes off their seat belt.
Get in the car and turn the key to on (don't start the car,) then change the odometer to display "odo" and not trip A or B.
Turn the key off.
Turn the key back to on. Within six seconds of doing this, press and hold the odometer button. Do so for 10 seconds. Then, while still holding the button, buckle up, edit: then unbuckle. The "odo" display should then change to say "b-on." let go of the odo button to get it to read "b-off." Then wait for the display to change back to the odometer. That's it, you're done.
The car will still beep right when you turn it on for 3 seconds if you don't have a seatbelt, but the dash light will continue flashing till buckled up. It won't beep if you or your passenger unbuckles for a moment. Salvation!
Read more: http://wiki.answers.com/Q/How_do_you_disable_a_driver's_seat_belt_alarm_on_a_pontiac_vibe#ixzz1MxTn2Oa0
