SOURCE: I'm missing the tonearm counterweight for a Gemini
hi,
i'm too missing the tonearm counterweight for my Gemini TT01. if you haven't figuered out where to buy one, do you know at least what is the weight that is needed to counter the weight of the tonearm or how to measure the tonearm so as to make a counterweight of my own???
thank you in advance
Make a note of the tracking force setting.
Make sure the turntable is level.
Unplug the power to the turntable.
Using the tonearm elevation control, raise the tonearm.
Manually move the tonearm in toward the platter.
Manually rotate the platter ClockWise a few turns to disengage any cueing mechanisms.
Set the Stylus Pressure/Tracking setting to 0.
Disengage the tonearm elevation control. The tonearm will either float or drop. This is why we have no power, just in case it hits the platter.
Adjust the counterweight until the tonearm floats exactly horizontal. Use the flat portion of the tonarm rest as a gauge.
Return the tonearm to its rest.
Dial in the prescribed tracking force on the Stylus Pressure/Tracking control. Play records.
